cledger Posted November 6, 2015 Posted November 6, 2015 Changed my cv gator last week now theres a knocking noise when driven so i thought i might of damaged the cv joint so ive just replaced it with a new one today an the noise is still there anyone had this problem before ? Quote
AdamB Posted November 6, 2015 Posted November 6, 2015 What kind of noise? Grinding, knocking, banging, tapping? Quote
cledger Posted November 6, 2015 Author Posted November 6, 2015 Its a weird one sounds like a flat tyre but i can feel it in the pedal Quote
cledger Posted November 7, 2015 Author Posted November 7, 2015 Nah ive checked that and theres no contact with it Theres no play in the wheel either so i dont think its the bearing Im thinking ive damaged somthing whilst removing or putting on cv joint Quote
5T4R7ET N/A Posted November 7, 2015 Posted November 7, 2015 Strip it down again and make sure you done everything properly.Little tip if you didnt know- You can remove the drive shaft from the hub by jacking the suspension up and it will come out. Quote
