Okay, well most of you may know already know me on here from my previous glanza I built to a pretty high spec. I did buy this glanza as it was meant to be a jump in and drive car for me, but that didn't plan out, I was totally ripped off by a lad from Facebook, after buying it at night (big mistake but thought I could trust him) I got home and the next morning started checking it out, there seemed to be a bolt in the throttle pulley holding the revs up to 2000rpm, as I loosened it off there was a tapping noise and it was getting louder, so I got it checked out and seems it's a head issue, to then discover I also had a gearbox leak from the shaft seal (oem lsd) again was very annoyed. I tried getting a part refund but he was having non of it!
So basically I now have to get the head off and get that all fixed up, have now got a new gearbox and have just bought a cusco lsd to fit in to it
Everything in the spec below weren't all on the car when I got it, I've had it around 2 months and spent a small fortune on it.
FULL SPEC!
This is my Toyota glanza 1996.
It has a lot of history and receipts and stuff which you don't usually get with most imports, it has nearly a folder full of paperwork with thousands spent.
Also has a lot of jap history and jap books etc, also has the import papers from when it was imported in the UK back in 2007.
Now the specs of the car are below, I've tried to list as much as I can from the top of my head.
ENGINE, PERFORMANCE AND COOLING:
Block was bored and honed to fit the following.
Wiesco 74.5mm Pistons
Pauter rods balanced
ACL bearing kit
Athena metal head gasket
ARP head bolts
ARP bolts through out the block
New crank re ground to fit .25 with ACL bearings and thrust washers to suit
Stage 2 ported and polish head
Zisco valve stem seals
Zisco springs
Ported and flowed
Baffled sump
Blue anodised lightweight pulleys
TD04 turbo kit
Actuator
Air filter from turbo relocated to front bumper
Braided water and oil lines
RW DEVELOPMENTS Race spec rocker cover and oil catch can
Braided lines from rocker to catch can
Fuel pressure regulator with rail adaptor
Blue magnecore compition leads
JD performance Engine torque damper
Toyosports intercooler
Oil cooler and relocation kit
Blitz racing oil filter
Toyosports half rad
Blue rad hoses
Blue Battery voltage meter
J-performance exhaust system (like new)
MANAGEMENT:
Greddy emanage ultimate with 3 bar map sensor.
This is the latest version (E) which includes launch control, it also has a plug and play harness which cost around £200 alone!
DRIVETRAIN:
Cusco lsd rebuilt with New plates and diff bearings
You can only get these new from RHD Japan and these are £531.56 posted to the UK plus import tax. Works out at a total of roughly £660 to your door then you'll need diff bearings IIRC £125 from Toyota
So close to to £800 of my hard earned money in one gearbox!
Act 6 paddle clutch
EXTERIOR:
Body work is generally good condition
Team heko wind deflectors
96 spec front splitter (varis bumper to be fitted!)
Black bonnet
Black Wong mirrors
Black rear spoiler
INTERIOR:
Cobreu reclining bucket seat
Brand new omp harnesses
Brand new omp steering wheel
Greedy Turbo timer
Boost gauge
Oil pressure gauge
Air/fuel ratio gauge
Water temperature gauge
Oil temperature gauge
Alpine stereo
OEM cup holders
Tigwian racing gear knob
Rear strut brace
Rear stripped out
False floor put in and carpeted black
HANDLING:
TRD shocks and springs
RSR adjustable panhard rod
WHEEELS, TYRES AND BRAKING SYSTEM:
Axe wheels 16x8j deep dish like new
New falken tyres on the front
Sport tyres on the rear
Standard disks and pads
HEL braid brake lines (front and rear)
LIGHTING:
HID headlight conversion
LED side light bulbs
LED number plate bulbs
LED interior bulbs
PART I'VE BOUGHT SO FAR!!!!
New standard gearbox
Cusco lsd
550cc injectors
Emanage ultimate p+p loom
Blue magnecore ht leads
Red extended wheel nuts
Varis front bumper (not yet fitted)
L.E.D's all round
HID kit
Pictures to come soon, just backing them up on photo bucket!
4CE2A2A0-C245-4411-AACE-721F9001EE6D_zps
B1CF541E-887D-432D-AE18-88F664C8937E_zps
E007FC23-22CE-4B9A-BC3B-134C4353EC71_zps
15D38CC0-4B8E-4F79-AD00-844E3257BF01_zps
5C2B2387-A7F6-4BA4-9496-898E8D87A116_zps
2FE5757F-9506-4E17-94CD-EB47902FAAF0_zps
6C39FC03-DC2C-4F5F-8298-9533D81EA1AA_zps
E14E10CC-3FF9-4D76-AF46-30F15D1DF699_zps
C753EF3F-CC57-4A32-918E-42F7FA945D77_zps
3A3B3F15-3797-498E-A369-AB9616FB4180_zps
BFEBEC62-CD78-481F-8009-8222E73B90DC_zps
239D29C0-9A95-4342-9B16-F65C788E7825_zps
Edited by GLANZA-MAN
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
Looks a decent spec dude shame about the problems didn't you wonder why the car was sitting at 2k revs when you went to view it?
I did yea bud but just presumed it was the icv that needed turning down, didn't think anything of it. Was also raining so I blame myself for not doing the checks I'd usually do!
Cusco he told me. It's from Luke ep
ah right I thought you said above you paid near 800 for it just thought it was strange when I recognised the picture think he was asking 350 or something like that
Just copied and pasted Mateys description.
Looks alright mate.. spec seems good enough. Shame about the issues u come across. Whats plans for it?
Seen another white 1 kicking around plymouth..
Varis front bumper livesports spoiler...
That was my old glanza, I bought off Facebook with a blown engine, rebuilt it and sold it to a close mate who I knew would look after it and she has been mint ever since.
Not very many plans to be honest, il just build it till I think it's what I want it to be. I want to be in the 300s though.
FULL SPEC!
ACL bearing kit
ARP head bolts
Zisco springs
Ported and flowed
Baffled sump
TD04 turbo kit
Actuator
Toyosports half rad
Blue rad hoses
MANAGEMENT:
DRIVETRAIN:
Act 6 paddle clutch
EXTERIOR:
Black bonnet
Black Wong mirrors
Black rear spoiler
INTERIOR:
Greedy Turbo timer
Boost gauge
Oil pressure gauge
Alpine stereo
OEM cup holders
Rear strut brace
Rear stripped out
HANDLING:
LIGHTING:
LED interior bulbs
Cusco lsd
550cc injectors
L.E.D's all round
HID kit
Pictures to come soon, just backing them up on photo bucket!4CE2A2A0-C245-4411-AACE-721F9001EE6D_zpsB1CF541E-887D-432D-AE18-88F664C8937E_zpsE007FC23-22CE-4B9A-BC3B-134C4353EC71_zps15D38CC0-4B8E-4F79-AD00-844E3257BF01_zps5C2B2387-A7F6-4BA4-9496-898E8D87A116_zps2FE5757F-9506-4E17-94CD-EB47902FAAF0_zps6C39FC03-DC2C-4F5F-8298-9533D81EA1AA_zpsE14E10CC-3FF9-4D76-AF46-30F15D1DF699_zpsC753EF3F-CC57-4A32-918E-42F7FA945D77_zps3A3B3F15-3797-498E-A369-AB9616FB4180_zpsBFEBEC62-CD78-481F-8009-8222E73B90DC_zps239D29C0-9A95-4342-9B16-F65C788E7825_zps
13CF6CCC-CD2A-4BF6-A793-5C74C9D67457_zps
Today I started the diff transfer, due to family comitments I ran out of time but.... I got the old diff out with the help from the guide on here to follow!!!
Here's a picture of the old diff out.
AD2C2691-87CC-4208-AC3E-208E4334EC74_zps
As you can see I've been attempting to change the old, standard diff and swap it out for the cusco lsd which I have recently bought.
I did challenged myself as it's not something if usually attempt to do, but i pulled it off, it did test my patience a couple of times but I managed to keep my cool and crack on. Here's a few pictures of the change over!
8973FA41-0745-4BEB-8909-5FA7B2543B78_zps
C3CBD067-B81D-4475-9608-F1643721E256_zps
7A57C76E-9420-459B-9E73-AE0F6CE4E930_zps
518977D7-45EA-4E92-8BD0-FA1F31B9A722_zps
75415DBE-8EB6-4FCF-8363-117DED42F4AB_zps
560215C1-FDE3-44DE-9BC9-EA9DD7E99431_zps
D9BC2F22-4376-4506-A99D-D522B6829D7C_zps
B4260E87-187C-43D3-8016-2DFF50F16207_zps
Your going to break your neck and probably your back the way you have your harness set up if you have a bump
How should they be fixed? They were like this when I got them and haven't used the car yet. Were going to use them for show but seeing as they're there I may as well use them, but in the correct way!
OK thanks what make r thet buddy
Il have a check for you buddy.
