GLANZA-MAN Posted November 13, 2015 Share Posted November 13, 2015 (edited) Okay, well most of you may know already know me on here from my previous glanza I built to a pretty high spec. I did buy this glanza as it was meant to be a jump in and drive car for me, but that didn't plan out, I was totally ripped off by a lad from Facebook, after buying it at night (big mistake but thought I could trust him) I got home and the next morning started checking it out, there seemed to be a bolt in the throttle pulley holding the revs up to 2000rpm, as I loosened it off there was a tapping noise and it was getting louder, so I got it checked out and seems it's a head issue, to then discover I also had a gearbox leak from the shaft seal (oem lsd) again was very annoyed. I tried getting a part refund but he was having non of it!So basically I now have to get the head off and get that all fixed up, have now got a new gearbox and have just bought a cusco lsd to fit in to itEverything in the spec below weren't all on the car when I got it, I've had it around 2 months and spent a small fortune on it.FULL SPEC!This is my Toyota glanza 1996.It has a lot of history and receipts and stuff which you don't usually get with most imports, it has nearly a folder full of paperwork with thousands spent.Also has a lot of jap history and jap books etc, also has the import papers from when it was imported in the UK back in 2007.Now the specs of the car are below, I've tried to list as much as I can from the top of my head.ENGINE, PERFORMANCE AND COOLING:Block was bored and honed to fit the following.Wiesco 74.5mm PistonsPauter rods balancedACL bearing kitAthena metal head gasketARP head boltsARP bolts through out the blockNew crank re ground to fit .25 with ACL bearings and thrust washers to suitStage 2 ported and polish head Zisco valve stem sealsZisco springsPorted and flowedBaffled sumpBlue anodised lightweight pulleysTD04 turbo kitActuatorAir filter from turbo relocated to front bumperBraided water and oil linesRW DEVELOPMENTS Race spec rocker cover and oil catch canBraided lines from rocker to catch canFuel pressure regulator with rail adaptorBlue magnecore compition leadsJD performance Engine torque damperToyosports intercoolerOil cooler and relocation kitBlitz racing oil filterToyosports half rad Blue rad hosesBlue Battery voltage meter J-performance exhaust system (like new)MANAGEMENT:Greddy emanage ultimate with 3 bar map sensor.This is the latest version (E) which includes launch control, it also has a plug and play harness which cost around £200 alone! DRIVETRAIN:Cusco lsd rebuilt with New plates and diff bearingsYou can only get these new from RHD Japan and these are £531.56 posted to the UK plus import tax. Works out at a total of roughly £660 to your door then you'll need diff bearings IIRC £125 from Toyota So close to to £800 of my hard earned money in one gearbox! Act 6 paddle clutchEXTERIOR:Body work is generally good conditionTeam heko wind deflectors 96 spec front splitter (varis bumper to be fitted!)Black bonnet Black Wong mirrorsBlack rear spoilerINTERIOR:Cobreu reclining bucket seatBrand new omp harnessesBrand new omp steering wheelGreedy Turbo timerBoost gaugeOil pressure gaugeAir/fuel ratio gaugeWater temperature gaugeOil temperature gaugeAlpine stereoOEM cup holdersTigwian racing gear knobRear strut braceRear stripped outFalse floor put in and carpeted blackHANDLING:TRD shocks and springsRSR adjustable panhard rodWHEEELS, TYRES AND BRAKING SYSTEM:Axe wheels 16x8j deep dish like newNew falken tyres on the frontSport tyres on the rearStandard disks and padsHEL braid brake lines (front and rear)LIGHTING:HID headlight conversionLED side light bulbsLED number plate bulbsLED interior bulbsPART I'VE BOUGHT SO FAR!!!!New standard gearboxCusco lsd550cc injectorsFuel pressure regulatorEmanage ultimate p+p loomBlue magnecore ht leadsRed extended wheel nutsOil temperature gaugeWater temperature gaugeVaris front bumper (not yet fitted)L.E.D's all roundHID kitPictures to come soon, just backing them up on photo bucket! Edited June 30, 2016 by GLANZA-MAN Quote Link to post Share on other sites
Whitenoize Posted November 13, 2015 Share Posted November 13, 2015 Looks a decent spec dude shame about the problems didn't you wonder why the car was sitting at 2k revs when you went to view it? Quote Link to post Share on other sites
GLANZA-MAN Posted November 13, 2015 Author Share Posted November 13, 2015 On 11/13/2015 at 5:34 PM, Whitenoize said: Looks a decent spec dude shame about the problems didn't you wonder why the car was sitting at 2k revs when you went to view it?I did yea bud but just presumed it was the icv that needed turning down, didn't think anything of it. Was also raining so I blame myself for not doing the checks I'd usually do! Quote Link to post Share on other sites
fordie_glanzaV Posted November 13, 2015 Share Posted November 13, 2015 Pics??? Quote Link to post Share on other sites
GLANZA-MAN Posted November 14, 2015 Author Share Posted November 14, 2015 On 11/13/2015 at 9:42 PM, fordie_glanzaV said: Pics???I've put some up but still have loads uploading. Quote Link to post Share on other sites
Whitenoize Posted November 14, 2015 Share Posted November 14, 2015 (edited) I'm sure that's a trd lsd a guy on here was selling he sent me the link for it the other day Edited November 14, 2015 by Whitenoize Quote Link to post Share on other sites
GLANZA-MAN Posted November 14, 2015 Author Share Posted November 14, 2015 On 11/14/2015 at 1:43 AM, Whitenoize said: I'm sure that's a trd lsd a guy on here was selling he sent me the link for it the other dayCusco he told me. It's from Luke ep Quote Link to post Share on other sites
Whitenoize Posted November 14, 2015 Share Posted November 14, 2015 On 11/14/2015 at 1:47 AM, GLANZA-MAN said: Cusco he told me. It's from Luke ep ah right I thought you said above you paid near 800 for it just thought it was strange when I recognised the picture think he was asking 350 or something like that Quote Link to post Share on other sites
GLANZA-MAN Posted November 14, 2015 Author Share Posted November 14, 2015 On 11/14/2015 at 1:50 AM, Whitenoize said: ah right I thought you said above you paid near 800 for it just thought it was strange when I recognised the picture think he was asking 350 or something like thatJust copied and pasted Mateys description. Quote Link to post Share on other sites
fordie_glanzaV Posted November 14, 2015 Share Posted November 14, 2015 Looks alright mate.. spec seems good enough. Shame about the issues u come across. Whats plans for it?Seen another white 1 kicking around plymouth.. Varis front bumper livesports spoiler... Quote Link to post Share on other sites
GLANZA-MAN Posted November 14, 2015 Author Share Posted November 14, 2015 On 11/14/2015 at 7:49 AM, fordie_glanzaV said: Looks alright mate.. spec seems good enough. Shame about the issues u come across. Whats plans for it?Seen another white 1 kicking around plymouth.. Varis front bumper livesports spoiler...That was my old glanza, I bought off Facebook with a blown engine, rebuilt it and sold it to a close mate who I knew would look after it and she has been mint ever since.Not very many plans to be honest, il just build it till I think it's what I want it to be. I want to be in the 300s though. Quote Link to post Share on other sites
GLANZA-MAN Posted November 14, 2015 Author Share Posted November 14, 2015 On 11/13/2015 at 5:19 PM, GLANZA-MAN said: Okay, well most of you may know already know me on here from my previous glanza I built to a pretty high spec. I did buy this glanza as it was meant to be a jump in and drive car for me, but that didn't plan out, I was totally ripped off by a lad from Facebook, after buying it at night (big mistake but thought I could trust him) I got home and the next morning started checking it out, there seemed to be a bolt in the throttle pulley holding the revs up to 2000rpm, as I loosened it off there was a tapping noise and it was getting louder, so I got it checked out and seems it's a head issue, to then discover I also had a gearbox leak from the shaft seal (oem lsd) again was very annoyed. I tried getting a part refund but he was having non of it!So basically I now have to get the head off and get that all fixed up, have now got a new gearbox and have just bought a cusco lsd to fit in to itEverything in the spec below weren't all on the car when I got it, I've had it around 2 months and spent a small fortune on it.FULL SPEC!This is my Toyota glanza 1996.It has a lot of history and receipts and stuff which you don't usually get with most imports, it has nearly a folder full of paperwork with thousands spent.Also has a lot of jap history and jap books etc, also has the import papers from when it was imported in the UK back in 2007.Now the specs of the car are below, I've tried to list as much as I can from the top of my head.ENGINE, PERFORMANCE AND COOLING:Block was bored and honed to fit the following.Wiesco 74.5mm PistonsPauter rods balancedACL bearing kitAthena metal head gasketARP head boltsARP bolts through out the blockNew crank re ground to fit .25 with ACL bearings and thrust washers to suitStage 2 ported and polish head Zisco valve stem sealsZisco springsPorted and flowedBaffled sumpBlue anodised lightweight pulleysTD04 turbo kitActuatorAir filter from turbo relocated to front bumperBraided water and oil linesRW DEVELOPMENTS Race spec rocker cover and oil catch canBraided lines from rocker to catch canFuel pressure regulator with rail adaptorBlue magnecore compition leadsJD performance Engine torque damperToyosports intercoolerOil cooler and relocation kitBlitz racing oil filterToyosports half rad Blue rad hosesBlue Battery voltage meter J-performance exhaust system (like new)MANAGEMENT:Greddy emanage ultimate with 3 bar map sensor.This is the latest version (E) which includes launch control, it also has a plug and play harness which cost around £200 alone! DRIVETRAIN:Cusco lsd rebuilt with New plates and diff bearingsYou can only get these new from RHD Japan and these are £531.56 posted to the UK plus import tax. Works out at a total of roughly £660 to your door then you'll need diff bearings IIRC £125 from Toyota So close to to £800 of my hard earned money in one gearbox! Act 6 paddle clutchEXTERIOR:Body work is generally good conditionTeam heko wind deflectors 96 spec front splitter (varis bumper to be fitted!)Black bonnet Black Wong mirrorsBlack rear spoilerINTERIOR:Cobreu reclining bucket seatBrand new omp harnessesBrand new omp steering wheelGreedy Turbo timerBoost gaugeOil pressure gaugeAir/fuel ratio gaugeWater temperature gaugeOil temperature gaugeAlpine stereoOEM cup holdersTigwian racing gear knobRear strut braceRear stripped outFalse floor put in and carpeted blackHANDLING:TRD shocks and springsRSR adjustable panhard rodWHEEELS, TYRES AND BRAKING SYSTEM:Axe wheels 16x8j deep dish like newNew falken tyres on the frontSport tyres on the rearStandard disks and padsHEL braid brake lines (front and rear)LIGHTING:HID headlight conversionLED side light bulbsLED number plate bulbsLED interior bulbsPART I'VE BOUGHT SO FAR!!!!New standard gearboxCusco lsd550cc injectorsFuel pressure regulatorEmanage ultimate p+p loomBlue magnecore ht leadsRed extended wheel nutsOil temperature gaugeWater temperature gaugeVaris front bumper (not yet fitted)L.E.D's all roundHID kitPictures to come soon, just backing them up on photo bucket! Quote Link to post Share on other sites
GLANZA-MAN Posted November 14, 2015 Author Share Posted November 14, 2015 Quote Link to post Share on other sites
GLANZA-MAN Posted November 14, 2015 Author Share Posted November 14, 2015 (edited) Edited November 14, 2015 by GLANZA-MAN Quote Link to post Share on other sites
GLANZA-MAN Posted November 14, 2015 Author Share Posted November 14, 2015 Today I started the diff transfer, due to family comitments I ran out of time but.... I got the old diff out with the help from the guide on here to follow!!!Here's a picture of the old diff out. Quote Link to post Share on other sites
GLANZA-MAN Posted November 16, 2015 Author Share Posted November 16, 2015 As you can see I've been attempting to change the old, standard diff and swap it out for the cusco lsd which I have recently bought.I did challenged myself as it's not something if usually attempt to do, but i pulled it off, it did test my patience a couple of times but I managed to keep my cool and crack on. Here's a few pictures of the change over! Quote Link to post Share on other sites
Rich-k Posted November 17, 2015 Share Posted November 17, 2015 Stunning mate! Quote Link to post Share on other sites
Fisher Posted November 17, 2015 Share Posted November 17, 2015 Good work buddy What gauges Are they and we're you get them from thanks Quote Link to post Share on other sites
GLANZA-MAN Posted November 17, 2015 Author Share Posted November 17, 2015 On 11/17/2015 at 4:19 PM, Rich-k said: Stunning mate!Cheers mate. Quote Link to post Share on other sites
GLANZA-MAN Posted November 17, 2015 Author Share Posted November 17, 2015 On 11/17/2015 at 7:20 PM, Fisher said: Good work buddy What gauges Are they and we're you get them from thanksThanks buddy and not sure on the gauges as there were there when I got the car. Quote Link to post Share on other sites
Fisher Posted November 17, 2015 Share Posted November 17, 2015 (edited) OK thanks what make r thet buddy Edited November 18, 2015 by Fisher Quote Link to post Share on other sites
Whitenoize Posted November 18, 2015 Share Posted November 18, 2015 (edited) Your going to break your neck and probably your back the way you have your harness set up if you have a bump Edited November 18, 2015 by Whitenoize Quote Link to post Share on other sites
GLANZA-MAN Posted November 18, 2015 Author Share Posted November 18, 2015 On 11/18/2015 at 12:12 AM, Whitenoize said: Your going to break your neck and probably your back the way you have your harness set up if you have a bumpHow should they be fixed? They were like this when I got them and haven't used the car yet. Were going to use them for show but seeing as they're there I may as well use them, but in the correct way! On 11/17/2015 at 11:29 PM, Fisher said: OK thanks what make r thet buddyIl have a check for you buddy. Quote Link to post Share on other sites
GLANZA-MAN Posted November 25, 2015 Author Share Posted November 25, 2015 Cleaning the gearbox up be for fitting, here are some photos. (Haven't finished cleaning it yet due to weather) Quote Link to post Share on other sites
fordie_glanzaV Posted November 25, 2015 Share Posted November 25, 2015 Give it quick coat of paint!! Lol Quote Link to post Share on other sites
