How often should the gearbox oil actually be changed next got an answer on that
Not that often for a normal car, some BMWs have box oil that never needs changed.
For a starlet that gets driven... properly, id do it every time you change the clutch. Or say every year or 2.
But there will be starlets going around with the original gear oil and run absolutely fine.
