nothing better then an acis manifold best of both worlds you will need the vsv and vacuum canister to and a way to controle the vsv at a set rpm
i agree...but most would not want to go through the hassle of setting it up on a n/a car unless it came that way
so the "corolla" mani as you guys call it, is probably the next best option for n/a....bolt on and roll
