  • 3 weeks later...
bend the bracket to the rear of the car its that that tensions it to spring open 1s the lever is pulled you just havent bent it far enough
keep your lever up
bend it till you feel it starts touching and pushing back out it works the same way on my gtt i checked
  • 2 weeks later...
Maybe the cable has came loose at the lever end ? Take it off and see and pull the cable with pliers see does that work. Seen a few other cars the same :)
the cable works, I need to hold the lever up with a rock and pry the fuel cap open.. Can someone send me a pic of their fuel cap on the inside? maybe mine is missing something x)
