Anmucam Posted January 8, 2016 Posted January 8, 2016 Hi all,Im Murray from the Scottish bordersI have a sportif which im working on to get through an mot but have some long term ideas for it.Looking for information for the best upgrades to start with Any info would be much appreciated Quote
Bluebear Posted January 8, 2016 Posted January 8, 2016 Welcome to the site!In terms of power, there isn't a right lot you can do with the 4E-FE N/A engine. One of the best mods is to source an inlet manifold from the 'bugeye' Corolla that also utilised a 4E-FE; these can net an increase of around 10hp. Other than that, there is also a certain exhaust manifold that can be used that has a 4-2-1 branch design, but I'm not sure what car that came from, as well as changing the exhaust system for a custom freer flowing system.Handling is where you can really concentrate with the N/A Starlet, with most, if not all handling mods that are available for the turbo Glanza, as these are a direct fit (coilovers, shocks/springs, braces, bushes etc). As far as I know, you can also convert the rear brakes from drums to discs by using a rear beam from a Glanza as well, although that could possibly be going too far if you're not tracking it etc. Quote
Dale SR Posted January 8, 2016 Posted January 8, 2016 Welcome along take a look in the progress threads you will find alot of ideas in there Quote
Anmucam Posted January 19, 2016 Author Posted January 19, 2016 Thanks for all the info, ill have a look Quote
