ChrisLeeBoost Posted January 14, 2016 Share Posted January 14, 2016 Anyone else ever had a problem with the downpipe off wepr ramhorn kit, my lambda barely reaches and now the cable has actually popped out of the connector because it was stretched because the Bung is so low on the downpipe Quote Link to post Share on other sites
hopalong_neil Posted January 14, 2016 Share Posted January 14, 2016 Haven't got a ramhorn but i do have a wepr evolution kit with downpipe and had a similar problem. I just soldered in an extension piece of wire to the lambda and it's been fine ever since. Quote Link to post Share on other sites
ChrisLeeBoost Posted January 14, 2016 Author Share Posted January 14, 2016 Yeah was thinking of doing that just kind of wanted confirmation before I went ahead with it cheers mate Quote Link to post Share on other sites
Whitenoize Posted January 14, 2016 Share Posted January 14, 2016 I've noticed this before why do they put the lambda socket so low on the down pipe does it have any advantages? I just put a Bung In Mine and didn't bother running a lambda sensor Quote Link to post Share on other sites
ChrisLeeBoost Posted January 14, 2016 Author Share Posted January 14, 2016 Guessing it's something to do with the heat of exhaust gases giving a correct 02% reading, but Jesus it's that low that I had to pull the both of the cables together to join them I couldn't get any slack from loom end whatsoever and it just ended up snapping, I'm gonna extend it on the weekend I don't wanna run without a lambda it has a purpose which I intend to keep it for Quote Link to post Share on other sites
starletezy Posted January 15, 2016 Share Posted January 15, 2016 I had the same problem on my WEPR Evolution kit I simply modified the 02 sensor wire and made it longer Quote Link to post Share on other sites
gorganl2000 Posted January 15, 2016 Share Posted January 15, 2016 i'd suggest one of you guys just notify sasha/wepr about this issue so he can correct it on the jig for future productionssasha is a helpful guy...and i'm sure its something he would do to make his clients happy Quote Link to post Share on other sites
ChrisLeeBoost Posted January 15, 2016 Author Share Posted January 15, 2016 Yeah I just used a block connector to extend the cable and heat proofed it not too sure how I'll check if it's working properly again unless I do a diagnostics check would that gimme a fault if it wasn't working? Yeah I think I'll throw him a message and just let him know about it he's 100% and a genuine guy Quote Link to post Share on other sites
