kbond Posted January 19, 2016 Share Posted January 19, 2016 I've had AN10 fittings welded on to make a race spec rocker cover and had to remove the baffle plate underneath to clean any metal and dirt underneath, but how have people secured the baffle back in place?CheersKeiran Quote Link to post Share on other sites
Ollieh17 Posted January 19, 2016 Share Posted January 19, 2016 Drilled the revits out. The tapped and bolted them on with loctite Quote Link to post Share on other sites
kbond Posted January 19, 2016 Author Share Posted January 19, 2016 That's what I have started doing just wanted to see what others were doingCheers Quote Link to post Share on other sites
adzy Posted January 19, 2016 Share Posted January 19, 2016 I'm going to drill and tap mine, then tack weld the head of the bolt to the baffle so It can't come loose. Quote Link to post Share on other sites
Scoobysvx Posted January 20, 2016 Share Posted January 20, 2016 I went for the welding option but it's quite difficult as the rocker cover is soft ally compared to the stanless baffle. Can still be done though Quote Link to post Share on other sites
Ollieh17 Posted January 20, 2016 Share Posted January 20, 2016 I tried welding mine but used the wrong wire then gave up. Tapp and bolt means you can clean it out again Quote Link to post Share on other sites
