My half rad is losing a lot of coolant and the car keeps overheating, there's no milky stuff around cams when I open up oil filler cap, and no foaming out of the rad and no visible signs of any leaks anywhere, any ideas lads it's been fairly cold around lately so there is a fair bit of condensation coming out of the exhaust at times, the last thing I want to hear is head gasket gone :(
Have you checked everything mate with the engine running? Even at the back where water pipes are, could be water pump seal, even heater matrix
Check the plastic screwy release valve where you drain it at the bottom..they usually have a shitty rubber seal that can split.
Haven't checked the water pipe behind engine yet mate will have a look tomorrow! The bleeder thing on bottom of rad seems to be fine and can't see any signs of leaking from water pump but as you said I should check with engine running, heater matrix is that a common problem? Is there any symptoms to look for when it's the heater matrix acting up?
Thanks for the replies lads I'm on the verge of pulling my hair out at this stage
