If I was to do my headgasket would it be ok to use oem gasket or something or should I go Athena steel gasket? Will be running 1 bar td04 at some point so just want to know which gasket to use before I go ahead with it :)
That's grand the price of them steel gaskets the multi layered ones, I know the saying goes buy cheap buy twice but I just wanted to know which gasket was best to use for the setup I will have :)
Sorted will get one from Toyota thanks Colin I probably won't be doing the gasket myself but will supply a genuine one for mechanic, will I defo need to replace head bolts
And if I do will I need ARP or will Toyota ones do
you can reuse the head bolts to i have on many occasions reused them for my stingy customers , BUT its best to get a new set if you can , buy them in a factors for 30e i think
if your reusing the old 1s make sure al threads are clean and no oils in the block threads
If they're that cheap I will get new ones il do it right going to do water pump and stuff while it's getting head gasket and I might do oil pump too! I don't actually even know if the headgasket is gone yet I won't know till Monday I don't have the time to be at the car with work and I need it for work :( so time to splash the cash I think
