Avinash Trance Posted February 6, 2016 Posted February 6, 2016 I have a Toyota Glanza V. I drove in the rain for about 45 mins. My engine is not running smoothly. What can I do? Quote
akyakapotter Posted February 6, 2016 Posted February 6, 2016 do you have a front mount intercooler if so will be water down the spark plug holes very common during wet weather Quote
Avinash Trance Posted February 6, 2016 Author Posted February 6, 2016 No top mount intercooler... i lift up the bonet the intercooler is humid Quote
Whitenoize Posted February 6, 2016 Posted February 6, 2016 Have a look in your distributor water may have got in Quote
Avinash Trance Posted February 6, 2016 Author Posted February 6, 2016 Yes...will have a look..hope it will be good Quote
Iwan-g-g Posted February 8, 2016 Posted February 8, 2016 Definitely water got into either plugs or distributior cap, I get it sometime even with top mount. Quote
gorganl2000 Posted February 8, 2016 Posted February 8, 2016 Definitely water got into either plugs or distributior cap, I get it sometime even with top mount. yeah, most likely scenerio due to weather you mentioned water in the distributor cap and/or plugs will cause it to run very rough and misfire Quote
Avinash Trance Posted February 8, 2016 Author Posted February 8, 2016 Yeah...i removed all the plugs yesterday. Guess what Third and Forth spark plugs were drendched. I wire brushed them.I put some gasket maker silicone on top of the plug wires where it fit the rocker cover. Quote
EP70-PT Posted February 8, 2016 Posted February 8, 2016 I had this, spray WD40 on your dizzy plugs and down the spark plug holes, it worked for me, use a compressor too if you can to get rid of all the water ;) Quote
Avinash Trance Posted February 8, 2016 Author Posted February 8, 2016 Yeah thanx. And by the way do you all use Iridium Spark Plugs or Copper? Quote
EP70-PT Posted February 8, 2016 Posted February 8, 2016 Sounds like a two stroke XD idk what spark plugs I have, just got the car x) Quote
Iwan-g-g Posted February 9, 2016 Posted February 9, 2016 I use ngk copper spark plugs. Used iridium in my old starlet and see no difference at all except nearly £30 extra for the iridium Quote
Avinash Trance Posted February 9, 2016 Author Posted February 9, 2016 So no need to spend more for Iridium. Quote
