Ok when the car is first started up from cold I get
65-70 psi which is around 4 and a half bar/5bar.
When the car is all warmed up and on idle I get about 20psi which is about 1.4 bar that's with the Rev needle on 1k revs,
Of course using the revs the oil pressure will go up and taking foot of throttle pedal it will go back down again, obviously if I used the screw on the throttle body and now idled at 1200 revs the oil pressure will go up slightly, hope this makes sense decdd :-)
Yeah that's absolutely spot on was just wondering what other people were reading off there's mine is very similar to yours maybe a bit stronger on idle even
Have done searches before on this and mine seems the same as a lot of others, did see something on here few weeks ago with one of them small hks oil filters suppose to raise the oil pressure abit aswell.
What makes you think you got an oil pressure problem mate what's happening
