Siwfc Posted March 7, 2016 Share Posted March 7, 2016 Hey people.. I've a vf35 top mount turbo and no oil feed return pipe. I know if I had the standard pipe it ain't gonna fit in a month of Sunday's. I know the od of the sump pipe is 19mm. Just asking what other people have done/used to link the 2 ends up. Thanks in advance Si! Quote Link to post Share on other sites
ChrisLeeBoost Posted March 8, 2016 Share Posted March 8, 2016 Get a braided hose made up with an 10 fittings on either end, get an an10 oil return adapter for the turbo and get an an10 Bung welded onto the sump Quote Link to post Share on other sites
daniel_g Posted March 8, 2016 Share Posted March 8, 2016 You'll need a feed pipe and a return pipe.I got both from zisco for around 70quid delivered. Quote Link to post Share on other sites
Siwfc Posted March 8, 2016 Author Share Posted March 8, 2016 Cheers guys.... I have a td04 oil feed and water lines, fit ok I suppose. Not into the water lines on the front of the turbo but hey ho. I've made a s/steel flange for the oil return and ordered a s/s weld on an10 fitting, same for the sump. When I order the braided hose is it a good idea to use ally fittings with the heat? Quote Link to post Share on other sites
