Andrew Miller Posted July 23, 2017 Share Posted July 23, 2017 To give you some background info this car had sat for 3 years before I bought it. Ive done the work required to get it on the road but have now ran into a few more issues.First off after 5k revs on full boost I get a misfire. I'm thinking its most likely the plugs as they look past there best but is there anything else obvious to check. Boost leaks etc?Secondly, after cruising at a set speed, if you lift off for maybe 5 seconds or more then accelerate again i get a puff of blue smoke. Ive checked the turbo and it does have some side to side play however no in and out movement at all. No excessive oil in breather and plugs arent covered in oil. Have yet to do a compression test.Any help appreciated Quote Link to post Share on other sites
morgey Posted July 24, 2017 Share Posted July 24, 2017 Plugs And leads would be the obvious things to check. The other thing are you sure its not overboosting and hitting fuel cut? Oil issue sounds a bit like valve stem seals, in some cases you can pull off both manifolds and look at the valves, sometimes you will see some oil resisdue on them Quote Link to post Share on other sites
Andrew Miller Posted July 24, 2017 Author Share Posted July 24, 2017 Im pretty sure it iant fuel cut. More like its just breaking up. Its fine full throttle up until about 5000 revs then it starts to break up. I did consider the chance of stem seals but thought that would cause it to be smokey on full throttle as well ? Quote Link to post Share on other sites
5e colin Posted July 24, 2017 Share Posted July 24, 2017 Plug gap for misfire renew plugs leads cap and roter set gap at 1mm to o.8mm Quote Link to post Share on other sites
gorganl2000 Posted July 26, 2017 Share Posted July 26, 2017 did you run a diagnostic?....if you haven't then you should...sounds like ignition issue regarding the misfire---distributor, coil, igniter, plugs, leads do you get any blue smoke on first morning start up? Quote Link to post Share on other sites
Andrew Miller Posted July 27, 2017 Author Share Posted July 27, 2017 Not yet haven't had the chance yet. Will look into it over the next couple of days. No smoke on start up as far as I can make out. Yesterday it was puffing out smoke once I stopped back at the house on idle and under light revs then cleared. Pretty sure its the turbo. Quote Link to post Share on other sites
SKINY Posted July 27, 2017 Share Posted July 27, 2017 My GT started to misfire on boost, king lead pretty much fell off in my hand at the dizzy end. Cap and arm weren't in great shape either so new cap, arm, king lead, plugs, oil and filter and it's flying now New cap and king lead was 55£ from Toyota and I used fiesta rs turbo plugs from Demon Tweeks, 17£ to the door, ordered at around 2pm and arrived at about 12 next day to Northern Ireland lol Quote Link to post Share on other sites
