Taggy
EP70 engine Conversion guide, 4E-FTE power
Well as no one else has made a guide on how to make a EP70 turbo conversion, i thought i would have a bash at it, so you can also take the piss out of my Welsh Accent. Car was originally a 1.0 litre, this guide shows how to fit a 4E-FTE turbo charged engine in it (while also keeping its original looks)
So here goes
EP70 Starlet Turbo conversion (This is a sleeper build)
The Starlet to be converted
A completely standard 1E, 1.0 litre(50hp) Mk2 EP70 Toyota Starlet - 1986
http://www.flickr.com/photos/bloke/sets/72157627453619308/
The donor car for the conversion (my old ep82 track car)
The end result of the conversion (Sleeper/Turbo power!)
Except its gone from 55hp to about 201bhp!
Tools required
I recommend getting your self the Halfords Advanced Tool set, £99 its really good quality and contains practically all the tools you need.
Soldering Iron
Drill
Lots of cups of tea
A handy friend to help!
Equipment required
An ep70 Starlet
An Ep82 Donor car
A complete 4e-fte engine
A complete FULL EP82 wiring loom
Difficulty rating
This is as hard as it gets so 5/5 spanners by Haynes standards, it took me 2 and half months to complete, but i had to figure it all out myself and I have documented everything that will trip you up. So you should be able to complete it in half the time.
Work required
Everything that was a pain in the ass was documented with video, everything from the EP82 is a straight swap into the EP70. The easiest way i found to do it was in this order.
1. Remove the old EP70 engine
2. Remove the dash
3. Fit in the additional EP82 Wiring loom (the car will now have two looms) one to power the engine and one to power the cars electrics.
4. Wire in the ep82 ignition to the EP70 loom
5. Put the engine and gearbox in
6. Swap everything else over from the EP82, i.e suspension etc
Have a watch of the vids below and you will get the general idea. I am always available for help if you need it.
Video guide
1. EP70(Boxy Starlet) 4EFTE Turbo conversion Part 1: Ignition key how to wire up
http://youtu.be/5MQpcrv8rPg
2. EP70 (boxy starlet) 4EFTE Turbo conversion part 2: EP82 to EP70 Loom Electrics
http://youtu.be/ol7YHovtOCI
3. EP70 (boxy starlet) 4EFTE Turbo conversion part 3: EP82 Loom Electrics install into EP70
http://youtu.be/4amELHxKJnI
4. EP70 (boxy starlet) 4EFTE Turbo conversion part 4: EP82 Loom Electrics, engine bay&inside car
http://youtu.be/gJcoVy1O1N8
5. EP70 (boxy starlet) 4EFTE Turbo conversion part 5: Moving EP82 Brake servo into EP70
http://youtu.be/zxxYepZQEEs
6. EP70 (boxy starlet) 4EFTE Turbo conversion part 6: EP82 Servo fitment
http://youtu.be/QHSrzLnaSuM
7. EP70 (boxy starlet) 4EFTE Turbo conversion part 7: EP70 Coilovers fitment
http://youtu.be/0Cg8KNxQTX4
7.5. EP70 (boxy starlet) 4EFTE Turbo conversion part 7: Engine mounts
http://youtu.be/CLMQjP-tuDs
8. EP70 (boxy starlet) 4EFTE Turbo conversion part 8: Engine mounts fitting advice (its bloody tight!)
http://youtu.be/BIQHRfBNhm4
9. EP70 (boxy starlet) 4EFTE Turbo conversion part 9: Redundant power steering pump removal
http://youtu.be/0UQMETn3NFI
10. EP70 (boxy starlet) 4EFTE Turbo conversion part 10: Track rod ends
http://youtu.be/EjkXtk-ovjQ
11. EP70 (boxy starlet) 4EFTE Turbo conversion part 11: Fueling setup
http://youtu.be/o0a0cgHYneo
12. EP70 (boxy starlet) 4EFTE Turbo conversion part 12: Starting engine for 1st time
http://youtu.be/6LnA-tAp7Io
13. EP70 (boxy starlet) 4EFTE Turbo conversion part 13: Cutting out all the unwanted wiring
http://youtu.be/skU7VmHH8to
14. EP70 (boxy starlet) 4EFTE Turbo conversion part 14: Figuring out how to fit the FMIC :)
http://youtu.be/lNFf5XM0m5o
Still got more to do with the intercooler, im havning trouble getting it to fit, i'll update this as i go along.
Hope you enjoy watching!!
Taggy
Share this post
Hey thanks!
I am just tidying up all the guides i have made over the last few years, SteveGT is doing somthing with them, so i thought i would post them in one place on his thread so he can add them :)
Moved this and pinned for you mate as I think it deserves it :p
Share this post
cheers for pinning this luke
Taggy am i ok to use this in the ep bible? Thinking the plan is to post everything in the ep bible but also have a seperate section on UKSC like TGTT's Awesomely helpful info section for all the guids and info so we have loads of technical on both places.
Share this post
awesum work tag! altho your missin 1 thing...........................................................................
....................... a fucking boost video lol great work work tho mate 4 sure
Share this post
Ha ha i have yet to taste boost in this, only had the car back 2 days ago from the workshop. I plan to take it out on boost this weekend :) I'll get some cheeky videos up.
Yes Steve no problem putting this in the bible, would appreciate it!
Share this post
Sorry what do you mean? I retro fitted the whole car from start to finish, have a look at the videos listed :)
Share this post
Thanks for videos and info Taggy, very usefull. Car is defenetly my style, good work :)
Share this post
Create an account
Register a new account
Sign in
Sign In Now
