970 -
Tamworth
3711 profile views
EP-Azz's Achievements
Boosting a Starlet (5/8)
Fuly Forged Immaculate 96 spec glanza 303bhp big spec
EP-Azz replied to EP-Azz's topic in Cars For Sale
I want an evo bro and this has now sold !! Took a big loss man but market is shite atm -
Year:1996 Model:Forged Toyota Starlet Glanza V Tax: obviously new rule cars dont come with tax MOT: june 2014 Mileage:138km on shell not even 2k on engine (have pics taken of clocks of oil changes and when i recieved car back from tuning developments from being ran in) Description: Stage 2 4EFTE built Engine Specs: Wossner 74.5mm Low Compression Piston Kit with Rings and Pins Scat 4EFTE Forged Conrod Kit with ARP Rod Bolts Athena 1.2mm Uprated Metal Headgasket ARP 2000 Uprated Headbolt Kit inc New Washers Genuine Toyota Full Gasket Kit Genuine Toyota Oil Pump Kit OEM Water Pump Kit OEM Cambelt Kit inc Idler & Tensioner ACL Main Bearing Kit ACL Big End Bearing Kit ACL Thrust Washer Kit Fully Machined and Polished 4EFTE Bottom End Fully Stripped, Cleaned and Rebuilt 4EFTE Cylinder Head to Standard Spec Block, Head and Rocker Cover Cleaned and Painted in the Tuning Developments Black and Silver Theme 430cc tuning development injectors Emanage blue ecu 8.5 mm spark plug leads Hdi front mount intercooler Tuning developments td300 billet wheel td04 WEPR ram horn manifold and downpipe with TIAL 38 mm wastegate with screamer Blitz nur spec r exhaust apexi front mounted air filter Apexi avcr black edition set at 1.4 bar 303.1 bhp curently running on an mbc as this seems to hold boost better OEM LSD gearbox Ogura ORC stage 3 clutch Ogura lightened flywheel Interior: Recaros evo 8 seats in very good condition no bolster wear or sagging Custom low sit rails Original jdm flare Optional extra floor lights Optional extra ignition barrel light Optional extra original starlet mats 98 spec door cards Fully Stripped and Painted shell inside Swoosh boost gauge Innovate lm1 wide and with gauge mounted in car Omp deep dish steering wheel stainless blue with horn Weighted silver metal gearknob C's short shifter Carbon dial surround Exterior: Optional extra Toyota wind deflectors Carbon goodies carbon bonnet in mint condition Freshly sprayed 96 spec front bumper with optional lip 96 spec rear bumper with optional lip 96 spec skirts Tinted front indicators 98 spec jdm rear lights Carbon glanza stickers Buddy club 15x7 gun metal grey in immaculate condition not one mark on them fronts have 4 mm tread marangoni zeta semi slicks rears have 5 mm yokohama parada spec 2s Lowered approx 45 mm Suspension/handling Dgr gen2 coilovers seen about 5k miles still fully adjustable (ride height/damping/camber) have c spanners too White line front anti roll bar polybushed Whiteline rear anti roll bar polybushed Whiteline anti lift kit with polybushes Ultra racing panhard rod Polybushed front and rear gearbox and engine mounts Cusco rear strut brace (adjustable) Cusco rear c pillar brace Standard front strut brace Celica gt4 big brake kit (off russ on her) 277mm with yellow stuff pads lots of use left . amazing brakes Rear ebc ultimax pads Shell is mint not a spot of rust on the bodywork .... polishes up and gleams like you wouldn't believe for a 19 year old car . No corners have been cut whilst building this , engine hasn't even done 2k miles yet had it fully run in and mapped by tuning developments with receipts to show this not even 6 months ago.......mapped on v power and always ran on v power , it's had more than 14k spent on it in the 2 years I've owned it and I know I ain't gonna see that back for it but it is a mint straight clean example and not gonna listen to silly offers. Don't want to let it go but have been offered a car I can't turn down ......have both build threads for this car on request if needed one from the previous owner (kierz) on here liam doyles brother which date back to 2007 when it came into this country and my build.thread from when I bought the car back in 2012 . Is a well known car on ukstarletowners.co.uk and i know many will vouch for the condition it's in and how much I've looked after it. Oil had been changed regularly always ran on millers 10w60 fully synthetic racing oil as advised by tuning developments. Also has a toad alarm with fob bad bits passenger headlight clip has broke but is secure couple of tiny marks on body work literally you have to look hard to see these price 6200 with private plate 6000 without ono Any real interested text or ring 07869413297 Pictures: Contact Details:07869413297
Sefton-EP91’s 98 Spec Forged Glanza
EP-Azz replied to Sefton-EP91's topic in EP91 Glanza Progress Blogs
Should hit that mate I'm running basically all the same blitz nur spec r and hdi cooler, tuning developments billet wheel hybrid td04 , wear ram horn mani n downpipe with tial 38 mm wg/screamer , EMB , 430cc injectors, 255lph fuel pump I made 304.1 @ 1.4 bar so good luck ill be keeping an eye on this bro ! -
No one got a door handle I thought I'd source one piece of piss ! Lol
Bump
Needs to be black
Got no pm mate on nights will be up.about 2ish today
EP-Azz's Billet Wheel'd 300bhp forged slag
EP-Azz replied to EP-Azz's topic in EP91 Glanza Progress Blogs
Finally got round to its first oil change .... 136154km it was at wen I picked it up from TD so has done just over 1000km since the build. Chose millers 10w60 as I've been advised to run it on this oil at all times just a few pics to show usin a gen Toyota filter as always -
Same turbo im runnjng mate spools well and pulls hard made 304bhp @1.4 bar
--maddox710-- Forged vf24 Build Thread
EP-Azz replied to maddox710's topic in EP91 Glanza Progress Blogs
Fuck that will you've just had a bit of bad luck .... sort the turbo n I'm sure the motor is good ! Up to you if you do though I may have some bits if you decide to break ☺ -
The top controller on that page amjad 25 quod one
