EP70-PT
    850
Everything posted by EP70-PT
  1. Edit! B-12V in L-12V out
  2. Exactly! I did my calipers green and my drums will be black so they're stealthy, also seen some competition drum brake shoes on bidjdm, could be interesting!
  3. Awesome project! Tugaaaaaa
  4. Yeah might do that mate, needs to be calibrated, I removed it when cold but it's weird, just goes up to the cold mark after a while and stays there
  5. I changed my clock faces for white ones from a Glanza S and now my temp doesn't work... Needle came up like 5mm and the engine was well hot already... Do I have to calibrate it or something after I had to remove the needle?
  6. I'm having a weird idle, when I disconnect the IACV it doesn't change at all...
  7. Awesome mate, doesn't even look backyard painted where's your exhaust though? Ahahaha
  8. Can't wait either mate! Body and paint costs a lot though, as soon as I can it'll be done! My goal is to take ir to japfest on april 30th ;)
  9. More bits coming from the UK! mint 96 seats and an HKS Hi Power backbox! pipe is mangled but will be fixed asap
  10. bump
  11. Bump
  12. He would have taken the attention from the show XD
  13. Who's in the video? We can see the UKSO stand briefly from 2:29
  14. I only need the fabric mate
  15. I commented on your post on facebook ahah João Campos mate
  16. Man that technique is mint! check that out!
  17. You need the pinouts for both and switch the wire around, it's simple mate but takes some time, it also gets frustrating when something is wrong and you can't find what it is
  18. They're not shift lightw they're boost lights so no it won't work. I'm sure there's already some tutorials around for the Glanzz clocks... What I did on mine was get some Starlet CD clocks and install Glanza S dial faces, the Glanza S doesn't have the boost lights so it's better for N/A
  19. Looking for the 96 rear bench (bottom piece fabric) got an entire set of seats, fronts are great and the back piece too, just that part has cig holes.... Anyone can help? Cheers
  20. Thanks mate judt the answer I needed
  21. The 96 Glanza seats are one piece and N/A two piece so it won't work mate
  22. What do I need for the conversion? The N/A seats don't clip in like the Glanza ones, and there's a white plastic that N/A's don't have... What's the full hardware I need before getting them sent over?
  23. Anything happened to this?
  24. Plastic mate
