ToyotaTech15
    2058
  1. Apprentice Technician for Toyota Gary
  2. An earth can be taken from a solid metal surface joined onto the body, ideally I would go for a body earth already made by toyota as you know it's a good earth. The live wire will go onto you ignition live, there will be 4 wires behind your ignition barrel, main live feed( thick red most likely) earth ( thick black) and two slightly thinner wires, you will need a test light or multimeter to test these two. One will get power when the key is in ACC position and the other will get power when the igntion is on, you need the one where power is at the wire with the ignition on. The illumination wire will go on with your stalk for the lights, again you will have a main live, earth and several others which only come live when they are switched, just connect it to the wire which is live when dipped beam or side lights are on. Hope this helps Gary
  3. You can see on this picture the bottom part of the grille is painted, But mines came just plain black and looks fine Hope this helps Gary
  4. Ill have a look at my pictures, but its the bottom line of the grille thats coloured Gary
  5. That's good mate Look forward to new updates Gary
  6. I've not got that sensor in my airbox, I believe it's the IAT sensor ( intake air temperature) and when I ran an hks air filter it was never in, It was an n/a engine thou Gary
  7. LOL Gary
  8. I work for toyota buddy, can get prices for you if you like Pm me Gary
  9. I work for Toyota mate and ive not seen much mods for 3ZZ or 4ZZ but the 1ZZ has a bolt on turbo kit that a customer has on his MK3 MR2, boosts performance by alot but dont know the full spec, the kit cost £4000 thou. I couldnt say if the 3ZZ and 1ZZ are compatible with mods but there isnt that much difference between them. without research its hard to say. Gary
  10. Seen a picture of this in japanese performance magazine in the JAE report, Looks amazing mate keep it up Gary
  11. ToyotaTech15
    Td04
    It's a rising rate fuel pressure regulator Gary
  12. I'm not sure on that, I don't know how much needs cut and what tools would be easiest to cut with. I don't know on wiring either, someone on here will link you to a guide tomorow I'm sure. Gary
  13. ToyotaTech15
    Td04
    Turbo itself through the I commerce on the site is £465 check Enzo's tong turbo shop, Minimum requirements of a uprated actuator blow off valve relocated filter and uprated rocker cover breather Although I would add a decat and manifold and management if running above fuel cut Gary
  14. ToyotaTech15
    Td04
    If it was me I'd go for a gt-spec hybrid or similar hybrid ct-9 if that's the power you would like to run. Gary
  15. ToyotaTech15
    Td04
    If it was me I'd go for a gt-spec hybrid or similar hubris ct-9 if that's the power you would like to run. Gary
  16. Yes the slam panel behind the headlights needs cut, I'm sure there is a guide. Someone has definately done it anyway Gary
  17. I do wheel nuts at work to between 100Nm and 110 bit I'm sure toyota specify 103Nm for the starlet Gary
  18. yes it's a charcoal canister, Mines does it aswell so it's fine Gary
  19. Well I'll have no more of it! And I don't care who started it!! Gary
  20. Cheers everyone, Nice to know everybody likes the work we do. @Sam ill pm you about the buckle the now. Had a few more problems getting the fiesta running properly, programming the Omex ecu is a bit of a puzzler, but it was running not bad tonight, after the Throttle possition was set and a few other settings. Getting some loud pops and bangs through the throttle bodies though lol. Gary
  21. HEY!!!! Stop spamming up my build thread lol Oh and Remix bumper are the win Phil! Gary
  22. Just a few pictures of the two starlets as i thought they looked good together and the ep91 looked lonely lol. Gary
  23. Update. Fiesta is now been running and is going for MOT asap, a few pics so far. Also just moved the Nova up to the garage, will be started soon Looks like alot of work but its really not that bad, Really mint shell and no rust really. More updates soon Gary
  24. Looking good bud, Seen you pulling away from the shell garage, sounds really nice! Keep it up Gary
