mrnoris
    17
    North London
1897 profile views
mrnoris's Achievements
  1. I used to work for Lexus which is how I got into starlet's. Just got my recall letter through. Looking forward to my free courtesy wash and replacement airbag. See if they notice any of my more subtle mods. As I understand it was first found on the sc430 (on lexus cars anyway) Obviously both car manufacturers and probably the airbag inflator manufacturer wants to minimise the recall. Maybe a year after that it was discovered these inflators were fitted to ct200h and is300h. To hear that it goes back as far as my 23 year old £300 shed is crazy. The cost must be astronomical. Probably costs twice that in parts, logistics, labour and admin. Surely takata must have been put out of business by now? Anyone know if they're still trading?
  2. De-Solv-it sticky stuff remover. I'm sure there is a proper chemical that the trade use, but I read it works and its like 5-6 quid a can from halfrauds. Spray it on, leave about 10 mins and use a plastic filler spreader to scrape. Metal will damage the paint. Repeat until its all gone and then rinse it off well.
  3. I picked one of these up a few weeks ago, recently restocked I believe. Still waiting for some bearings to come through so I can do Morgey's solid shifter mod at the same time. I would rather increase the leverage at the shift lever end as Trevstar said, and probably will at some point once my mate fixes his welder, but the Hypersport kit is only cheap so I thought it was worth a go.
  4. PM'd him and within 2 hours I was on my way to collect. He did all the little fiddly bits while I was on route and then rewired AND fitted the clocks for me and made sure all gauges and lights were working. They look brand new, and it was more like having a mate help you out than a purchase. Top bloke, good example of what I like about this community. Cheers
  5. Likewise. Good to bounce some ideas off you, and thanks for the master fitting class! Above and beond the call but very much appreciated! Keep at it.
  6. I will look into it for ya mate. Sorry I didn't see your wanted post. Main issue is going to be packaging. Most poster tubes aren't wide enough so I am looking at the cardboard pallet corner protectors. Just want to make sure they dont get folded by someone! Now I know you are after them I will keep hold of them until I have worked out the best way. I'll PM you once I have a rough idea on package dimensions and grab some quotes. NI yeah?
  7. that gearbox casing! Those OEM options! those headlight covers! Love the NA direction, the subtle mods on the interior and the standard you achieve. A mate of mine is running a Megasquirt kit he built on his 8v Carlton turbo estate. Lots to tinker with, lots (for me) to learn. Interested to see this progress, very inspiring for a noob like me.
  8. Shame about lack of support for legacy software. The work from the Mods is very much appreciated. Not sure how many people this will affect, my usual desktop machine to view the forum is setup to forget everything on shutdown, and I notice there is no way of getting to a secure login page (E.g. https). - even if you jump to a login error page - ( http://www.ukstarletowners.com/login/ ) Just wondered if this is planned to change or not and I will update my practices accordingly?
  9. Little update: Before After sidemoulding delete (forgot it on original list) On a related note, I have a full set of side mouldings and solida badges in reasonable nick, free to collect from North London area in the unlikely event anyone is interested. Will keep them for a couple weeks in case someone is going for the stock look otherwise I cant store them and they will be binned. Really needs clear side repeaters now. But will happen after I get back from hols. Also really needs OSF wing. Anyone know a good scrap yard/breakers in norf london/herts area? Or anyone got one in 1A0? would like to avoid farting about with paint if I can. Booked an MOT last night "half price" £29.90 (usually I wouldn't go for a cheap MOT but I would do any repairs myself and I know the garage). Only passed! advisory on hazed rear plate and rear tread. So far its been a very cheap, reliable little motor! I feel like she's earned an early service. Also going to clean/check calipers while i'm at it...
  10. Thanks akyakpotter. No rush I'm just doing preliminary research at the moment. Any other oem options go straight on that are the same size or smaller?
  11. Guilty, your Honour! Sorry couldn't resist... Based on what people are saying here: http://www.ukstarletowners.com/topic/101218-best-exhaust-manifold/ Would likely be an ee100/101 from a scrap yard to keep things cheap (if there are still any around). I need to do a bit more research for myself and also likely to be dependant on whats available. Would love a 5efhe manifold but I don't even know what they look like plus they are extra hard to come by... Having to manually research what things look like thanks to photobucket is a pain, but I wont let it hinder my progress. Plenty of work arounds ;)
  12. http://www.ukstarletowners.com/topic/105452-is200-steering-wheel-in-97-glanza/ Saw the above on my trawls and an IS200 wheel sounds appealing since they are pretty cheap my wheel is going manky and pitted etc... Just wondered, anyone know if they are the same diameter as original EP91 N/A? dont mind smaller but dont want to go bigger. I remember them being satisfyingly small in the IS200s but it was over a year ago I was in one...
  13. Couple weeks ago I had enough of the audio so: pulled the sub to get theile small parameters for rebuilding the box, in the end the box is basically close enough to the correct size so just refurbed it. previous owner bodged the port up had this in stock trimmed the flange off the internal flare and flattened one edge for clearance added neoprene gasket... love this stuff - everything that screws to the box got this added to it original internal wire vs new 14AWG pure copper testing with a computer PSU soldering the power teminal routing power cable through OE loom trimmed the mounts (badly) and added a gasket to seal against Somehow I managed to not get pics of the 4” alpine cheapo 2ways I fitted in the front. Theyre ok I guess, zero response below 120hz though. Might try to do a custom build with 6” in the front when I get time/money. I know the sub is going against the philosophy of lightness but for now I need a bit of bass and I had it in stock for a few years and never heard it. So it’s staying for now since I just refurbed it. Port is about an inch too short so tuning frequency is 40 odd hz rather than 31 which is what the software recommends for flat response. So it has a slight peak at 40hz but my sensitive ears can tollerate it (and I have trouble with many club PA systems). Found out my alpine HU has an intermittent fault on the low level (sub) outputs so it has been sent to the approved repairer. Was going to have a go myself but I absolutely love that HU and for £60 they are responsible for it (stuff I dismantle doesn’t always reassemble!). It's been with them over 2 weeks now. The engineer has called to say they agree it has an intermittent fault but can’t get it to do it while the unit is apart, only when it’s together. So need to do more testing. That’s all for now… I guess a to do list will help me keep track of my progress so: Needs doing: Sort alternator belt squeal (fingers crossed) Intermediate service NSF knocking – had a pry when I was working on alternator belt. Still cant find obvious culprit. Want to do soon: Front end repair Yaris rear wiper arm (seen on pinske’s progress thread, mines bent) Glanza cup holder OS parcel shelf rubber SR clocks Clear side repeaters, silver indicator bulbs Rolla inlet mani 4-2-1 exhaust 4/7afe throttle body 100PS ECU air filter upgrade Change steering wheel Glanza/celica ST202 brake conversion Used coilies, top mounts and panhard General clean and tidy exterior 96 spec glanza rear clusters with custom reverse light Once I am there or there abouts, I will re-evaluate the direction its going in and my finances and see where I want to take it next. Would love a 2zzge but more likely to be a turbo 4efe in future if at all. Any advice on NSF knocking appreciated, otherwise its going to end up with swap outs starting with cheapest and working up. My gut says topmount but its not visibly dead…
  14. Once these tyres and wheels went on I fell in love with the car. So a plan has been hatched, and the general aim is relatively subtle, cheap, and era appropriate mods where possible prioritising in descending order: Cheap daily driving Fast road –ish Make it a bit more desirable but not baitcar I am as skint as I usually am at the moment so starting small and working my way up: Gingercator delete – (Thanks for the guide Morgey! Saved me some broken clips) Looks like that bodge repair has been done more than once since there is an aftermarket cluster in there. Had to enlarge the clip holes to get OE lense to fit. Will silver the inside of the clusters and bulbs once I have sourced and fitted new wing bonnet bumper and cluster. Spent most of Saturday farting about cleaning my shed and then dealing with the alternator belt squeal. So far so good. After lots of research on here I thought the alternator was seizing but not too sure now. Checked all pulleys for play, free spinning, alignment etc, added a bit more tension, sprayed some maintenance fluid into the bearing on the front of the alternator and cleaned everything with brake cleaner. Looked to me like my WP and alt pulleys are out by the thickness of a pulley face: Anyone confirm this is how they are supposed to look? Belt looks shunted over to me. Anyway no squeal yet so fingers crossed.
