ryan lang
    8959
  1. updated my chrome £543 and now it works
  2. whatt :s can you not see it in my post that they havent worked :s £150 £45
  3. as above, in my for sale thread i cant use £ the pound sign next to a number, like so £12
  4. have you got the gear shifter, brake and clutch pedals, and selector cables? maybe even the clutch master cylinder and slave cylinder ryan
  5. ahh let down, when you said photo's from down under, i thought you meant from down under ;) looking good though bud
  6. if i had a starlet id have bought them lol
  7. awesome price tbf considering what i paid for mine
  8. 1st post ;) the diff oil seal has gone so gunna have to take it off today and check it over for more damage
  9. any chance of a lift james? seeing as my cars now fucked lol
  10. px for a mk1 mx5? lol ryan
  11. this was also spotted on the fastcar website on a sad sad sad note, my diff shit itself! needs a new oil seal at best, or a new diff at worst ryan
  12. hi guys need a 4efte knock sensor asap if anyone knows of or has one ryan
  13. have you checked the battery with a multimeter to see if its being charged from the alternator? check batt with engine off, then start the engine and it should go up to 14v. sounds more like a dodgy earth cable, mine was loose on the battery and every now and then popped off and used to cut out if i was cornering hard, tightened the connector on the battery, problem went the earth points are gearbox mount, top of the gearbox back of inlet manifold and on the slam panel iirc, just undo them all, wd40 the contact area's and end of wire connectors, wire brush them, and re-bolt them back up tightly. also check the entire length of each earth wire because if has worn to metal anywhere and touches the metal the earthing point may jump temporarily and cause it to cut out. you can buy the connectors for the battery from most motor factors if yours doesnt fit tidy that will also cause it to jump, for a temp measure, you can fold up some tin foil and wrap it around the terminal and tigthen the connector around that
  14. the boot plastic was rattling like a bastard on mine so i put padded foam tape around the back of the plastic and it went
  15. my car was broken into a couple of motnhs back, thank god i have no money to have anything expensive in there at the moment, but what they did take was worse than stealing parts the bastards! they took my last £10, a usb stick, sunnies, gloves and my college bag full of almost a years worth of work :/ which i had to re-do and copy up on didnt bother with the cd player or steering wheel. they popped the bonnet, and pulled a section of plastic from the steering column off, but no wires were touched so i guessing they were looking for the boot release button, luckily there wasnt one, but i bet the bastards have seen me in and out with my tools and chanced it
  16. awesome, ill get the postcode up in the 1st post aswell then
  17. okay awesome stuff guys and girls ill update the 1st post now. where are we doing it? usual brecon spot? although it sometimes causes confusion
  18. pretty sure its a lip not a bumper isnt it? i know tom has one on his glanza too still unsure on those rear lights though dude :s but everything else looks awesome
  19. how about august 1st? wednesday night? ryan
