tom_1593
    82
Everything posted by tom_1593
  1. Hi mate do you have both front window regulators?
  2. Anyone?
  3. As above. Anyone got anything?
  4. What are these like on the gt? Do they stick out too much?
  5. Is there any aftermarket wing mirrors that fit the 82. Mine have pretty much had it. Pics would be good too?!
  6. Are these the right bulbs for my gt back lights. I have my fog light wired into the back. />http://item.mobileweb.ebay.co.uk/viewitem?itemId=280849394597&index=9&nav=SEARCH&nid=47892607128
  7. Anyone?
  8. Need a td04 Mani to turbo gasket. Anyone??
  9. Anyone know where I can get one of these?
  10. Pm me too please
  11. How do I extend the Lamda sensor wire. I recently bought a Wepr mani and down pipe but the hole for the Lamda sensor is quite low so doesn't reach the plug. I have tried extending it with a bit of wire but don't think it is working anymore. Is there anyway to check its working. The engine is running slightly rough on idle now too.
  12. tom_1593
    Reverse scoop
    @starbuck what do you mean painted in tgtt @Marc Ross I'll drop you a txt soon
  13. tom_1593
    Reverse scoop
    Tried to pm you but isn't working. Pm me and I'll reply.
  14. tom_1593
    Reverse scoop
    Cheers. I'll have a look now.
  15. tom_1593
    Reverse scoop
    Want a reverse scoop for my 82. Carbon preferably but will have normal one too.
  16. I was just gonna replace all of them. I will look into how much it will all cost. Can I get the spark plug seals from the same place?
  17. Where can I get new gaskets for this? I'm going to paint my rocker cover and thought I would replace gasket and seals.
  18. Anyone know the difference between the Td04L and a Td04HL
  19. I used the ct9 return and haven't had any problems do far.
  20. Right just got a cv joint from camskill but it doesn't fit. It's the right spline count and fits the shaft and the hub but when I tighten the big nut it pulls the joint tight against the hub and won't turn. it also has splines on the outside of the joint. Is this for abs? I ordered one without abs and it says on the invoice without abs. It's the second one I've ordered and both came with the splines in the outside. Oh and I don't have ABS. can anyone help?
  21. I know that I mean cut the shell to fit a manual box. As in the gear lever linkage because it will be different from the auto
  22. Would it matter if it was automatic? If you had a 4efte with a manual box would it not fit with a bit of cutting for the gear lever?
  23. I would defo say cv joint if it only knocks when turning.
  24. saw this in glasgow city centre a couple of months ago then a few days later followed it down the road
