malanga31
    11
About malanga31
  • Birthday 10/31/1985
  • MSN
    manuel@websolutionscr.com
  • Website URL
    http://www.tercelteamcr.com www.websolutionscr.com
  • Skype
    manuel.cantillo31
    Costa Rica
malanga31's Achievements
  1. hi guys, I have a prob with the launch control, if I put some degrees off on timing... the car just shutdown :/ heres a video: https://youtu.be/WccjYrx2ATk Anyone can help? It's a 4efte from a ep82 .... I used the boomslag arnees.... Thanks!
  2. hi guys, I have a prob with the launch control, if I put some degrees off on timing... the car just shutdown :/ heres a video: https://youtu.be/WccjYrx2ATk Anyone can help? It's a 4efte from a ep82 .... I used the boomslag arnees.... Thanks!
  3. Hi Friends!!! What is he maximum temperature supporting the EGT 4EFTE engines? fully forged! Interestingly Sock's project, 400bhp is incredible. I currently have a project with similar specs and are my maximum EGT of 1400F to 1.68bar boost. Use spark Grade 7 and the last dyna test gave 316bhp..
  4. Changed sparks same thing
  5. OK, I will change them to, Will NGK grade 7 with a .22 gapped will work fine? I'm boosting 1bar.... stock internals..... Here's a video , I know is not the point... but.... hehe >http://www.youtube.com/watch?v=4JLZoZ2Rm2U
  6. Well I set it to 10 regress... Same thing.... Any other thing? If I rev it to 2000rpm it start to go 1800 - 2000 and afr start 14.7 16.0 ....
  7. I tried the order day with the EMU just put -5 all around 500 - 1500 rpms, but did not help at all.... I will try it mechanically....
  8. 12 degress , at the EMU I can see it 10 - 17....
  9. Hi guys!! I have a strange problem @ idle with my engine. AFR it's 14.7 - 15.0 and rpm 800 -1000. The problem is that the exhaust starts popping when warm..... but if turns on the lights or the A/C it almost stop doing it. Here;s a video: >http://www.youtube.com/watch?v=MKMAjtCJ-As I changed coil, leads, cap, rotor..... Thanks!
  10. Hi guys! I just bought a new turbo from subaru wrx it's a TD04L. Have a problem with it, I just installed it, but it's smoking.... I'm using motul 5w40 100% synthetic. He only smoke with the turbo is on full boost, or when I'n under compression.... I do not know, if can be the oil restrictor? suppose has to be a M10x1.5, but I done really know.. Maybe you guys can help me, Thanks!
