gibby1980
    42
1 Follower
  • MSN
    jasondgibson@hotmail.com
    Barbados
gibby1980's Achievements
  1. You still have this car? I run a gt2871r as well on my 5E. Stock bottom end. I did a 2nd gear pull and logged it via the EMs-4 and read 19psi and hog rich on pump gas as well. (RUBIS) but quickly ran out of road. Boost starts around 3 and really kicks in around 4.5k rpms all the way to redline. With these Garretts, the boost doesn't spike like a CT9. It's more of a linear progression where the boost follows the RPM. I'm not sure if others have the same results.
  2. Hi all, I got this working finally. I changed my Dizzy, used the 24-1 Crank and Cam pickup, and lowered the coil dwell from 3ms to 2.5 ms(got that on a supra forum). While I had these settings in place earlier I was advised the dizzy might be going bad so hence the switch. The car is running much smoother and the issues seen before are now gone. I still have more work to do as I have the boost solenoid connected to the ems-4 and have the boost governed by rpm currently. Ideally I'll like to switch this to boost by speed.
  3. Reading in 2020. Good info lives on forever gents!
  4. Hi Sam, Thank you for the input. I will gap the plugs a bit closer to see if things improve. I will go COP (From the 2zz motor) with a modified dizzy (Similar to AEM EPM unit with the 24-1 nissan wheel and optical sensor ) if I don't see any positive change come next week. Gibby
  5. Rich at startup? Rich while running? Cut some of the fuel from the fuel VE table. Who tuning your car?
  6. Good day all, Is anyone running the AEM EMS-4 on their 4efte/5efte with the stock ignition (dizzy/distributor)? I am asking because I seem to have "noise" on the cam input which cause the car to sputter & jerk between 3k-4k rpm. Once you clear this area, the car is smooth. I logged and reviewed and it's not lean in the specified area. I've read you can use resistor to clean this up so the car can rev out clean but I have not seen a write up or pics on how to do this. Have anyone installed this EMS before? If yes, did you all have similar problem and how did you solve it. Any information would be appreciated. Kind regards, Gibby
  7. On the gauge, at idle you should be reading -20 or a bit more.
  8. What turbo do you have on? Any vacuum leaks noticeable on the boost gauge?
  9. Try changing that map sensor and do a diagnostics test again. See if it's the same. Does the software for the dastek show the same 8psi? I would see that in tunerstudio for the Megasquirt. Confirm if the dastek is tuned for the higher rpms/boost?
  10. What ECU are you running by chance? If standalone, is it tuned for boost?
  11. take a datalog and see what is happening..... I had an issue like that with the Megasquirt. The overboost protection value was too low and I also re-scaled my tables. Had to remap.
