Rich
Member-
Content Count
860 -
Store
Calendar
Everything posted by Rich
Shweet! cheers guys will come in handy at some point I'm sure. Well I guess the only way of raising RPM is the hardwiring of some oscilatng resistor thingy without going into mega bucks.
I don't think Shelly wants us to go ;)
Well I want to but need to get a few things sorted first. Would also need to check AFRs when raising and Ignition timing ETC.. Also I don't see how regrinds work, do they add more material then grind it off? Otherwise you would have worse cams than you started with surely... Need to read up more lol
Freebees? ;)
You can do it that way, I don't know if Ultimate or the likes can do the same thing. Rick how did you raise yours? But yeah 6200 rpm is feeble ;)
Yeah c'mon people I'm supposed to be a Thursday person ;)
Or need bleeding, advisable to do it when changing disks and pads mainly because you working there anyway.
It won't do any long term damage, its there incase there are any imperfections in the making of the seperate items. Like i said if it runs and idles good then it should be ok.
★ Project 赤い脈動 EP 九一 ★ 14/06/12 - Interior and Exterior Update! ★
Rich replied to Jozinobi's topic in EP91 Progress Blogs
They look fricking awsome nice match to the wheel nuts aswell! Noticed any difference with the your bar? I guess it all adds up, is there anymore handling mods left? or are they all on the EP ;) -
ARB is 5x better than the manifold for improving the starlets characteristics ;) I also recomend (so would most people) 3G disks and greenstuff pads..
So you didn't have a gasket with the old manifold? :S if you say it runs fine and idles fine then thats all good but I'd still get one for peice of mind. Best way I find to propperly reset the ECU is disconnect it from behing the glove box ;) You know its reset when you start it up next, it tends to want to stall but revs itself back up. leave it idling for 5-10 mins then take it for a good drive through all gears with hard and easy driving.
Didn't see that ;) ...
Its gona be the pipe, I managed to move mine by unclipping/unbolting it from the fire wall... The small pipe is attatched to an electronic box which is to do with the Air sensors. Ste I used my original one you should be ok unless it rips or something.
^^ Lol what straining to take a shit?
Yeah I think so, but if you kept it as a closed loop but had it detour into a container of some sort, it should still work. Theoreticly
Well the other day I took my throttle body off to give it a good clean, there were some nasty deposites on it and Idle was dropping to 500rpm on occasions. Then I noticed inside the inlet manifold there was a nice pool of oil so I whipped that off and gave it a good clean also. Now my question is, Is it against the law (MOT law ) to have an oil catch can attached to the PCV?
That would probably be high enough compression with the headgasket as its meant for the 4E anyway. Austrailians eh.. only thing they ever invented is the rotary washing line, but when it comes to Toyotas theyre just plain mad, good but mad! If you got the e-manage for a good price then why the hell not, I swear you get everything for a good price lol (I'm just jealous ) Oh Ste - I think he will be on the dyno when the e-manage gets tuned -
Kooool, Emanage Ultimate... Wouldn't emanage blue of surficed? I suppose you've got more to play with, with that - nothing but the best. And a seriously nice collection of Rare parts there man congrats on sourcing them Like I said gona be savage and don't hold out on us with long periods of no updates Oh and a quick note, if you want more compression use the 4EFE pistons, they got a bigger dome -
Nice one Joz what are the ITBs off? 4AGE? Also what you gona use to control them? Make sure you do a mega write up when its done gona be savage Great work mate (or should I say great work to you mechanic ), keep it up -
That was when I was doing it, the whole floor is sprayed Flocked dash will be lush
Angle Grind0rz? Would just have to get used to doing doughnuts at every corner
Adele - Hometown glory (High Contrast Remix) http://www.youtube.com/watch?v=32z7USfMD1s
Coolios, yeah its only a week and 4 days not that I'm counting or anything. Same thing happened to me up town, were you on WKD blue and port aka Bitchpiss, cheeky vimto whatever you wana call it.
like I said If i'm right in thinking they use the same bell housing bolt pattern as the E series engines go for an ae86 box
It does look better in the "flesh" should of gone to the maidstone/bluewater meet but was busy
