How good really is emanage blue?
Just found out that emanage blue works perfect in my Daihatsu and its even featured in the japanese instruction manual! I know emanage ultimate doesnt work for some reason. Been told you have to modify the ECU for it to work correctly which I find strange.
Current set up is an apexi SAFC2, turbo smart FCD and uprated injectors.
Would emanage blue with injector and ignition harness be much of an advantage?
Scott.
I have an ultimate installed in mine. works perfectly and better than the blue. very easy to wire in and tune yourself.
he's talking about a daihatsu...not an ep91
so his ecu/sensors may be different as its allowing emb but not working with emu
