You are sleeping better when You know those are powercoated, have to do same for my P7. Once looked Toyota price for those mounts and they were very cheap, but I guess nor available anymore. More pictures about intercooler? You should paint it black with heatpaint, more sleeper look...
  • Replies 83
No, you can't buy them anymore, and the left one in the front has a habit of rusting pretty much. But now they should last very long 😊
I got some on my computer, can upload later. I have thought about painting it matt black, because it' also more efficient when it's black. And it's more hidden, the danish police doesn't like modified cars that much 😉
#TBT !
On request, I'm uploading a bunch of pics from the build today. They are from when I bought the car till today.
I've used approx. 250 hours on the bottom, and the result speaks for itself. I build my own carbon ramair headlight to use when racing.
A good friend of mine used a whole day on the wings and fenders, knocked them out with a hammer, and the car is now 15 mm wider on each side in the rear and 10 mm on each side in the front. It's been made so it still fits the car and looks original which is the plan. That's why I call the project a resto mod.
B779B1FB-BDC4-4CDA-8001-08E4933F16A7_zps
369FAFCA-6903-43FD-8564-9C1B596BEAC2_zps
Removing this original body sealer is a piece of sh*t. In total it weights 18 kg.
40DEC249-43DF-424C-BD7B-2F19C9594E8B_zps
Project clean enginebay started like this. Cleaned the bay so all holes were visible, and afterwards closed all holes that wasn't gonna be used. It's done right with a welder and tinned afterwards.
AD71BA72-0EAF-4419-AF7A-F85CD8A186CE_zps
9E065FAC-E635-44E0-BFBB-5913F1172005_zps
All corners on the bottom are sealed after the first layer of paint. It's becase the paint is thinner than sealer, so it goes deeper and protects.
5FCF2C0B-8C9A-40DC-8274-2C65F2BF803E_zps
Here the fenders are widened. Looks really awesome on the little boxy
445B385F-5EF0-4D3E-8893-918465CE3BD6_zps
4E5ECEAE-F56F-47BE-8884-4E9FEE99CF04_zps
Freshly powdercoated parts ready to be fitted. All bishings are replaced with powerflex purple line. Front wishbones are new.
52532064-CE50-42DD-87A4-7D2B73643354_zps
74947CB6-5F8C-4292-B3DD-691A0EE5E7E0_zps
Special mounts for radiator, oil cooler and intercooler has been made, so it fits the way I want it.
BFBE8D23-E67D-4103-BD8F-F09BD90E55B6_zps
My homemade ramair headlight.
FA95B41B-91D0-499B-B0D8-AFC950F4708C_zps
37475458-018F-492B-99AB-A1B4DFB85055_zps
50716041-CE1E-414F-949D-B684E063F943_zps
Homemade mount for walbro 255 fuelpump. It's made so the pump sits on the bottom of the tank, and with AN fittings.
89F679CB-031A-4691-A4CD-A98165206987_zps
Had a small photoshoot of how far I am with the ride for now. A lot has been made since, but a couple of nice pics came out of it.
6382A1CB-EF19-4EA5-90D5-8E400B418139_zps
Yeah a couple of hours has been used already. The engine will get even more attention to get a look that's not seen every day.
Actually don't know much about the interccoler, bought it of a friend who bought it from poland, a size too small for his starlet, but it's capable of flowing about 450 hp. I don't even have the dimensions on it.
Nice size cooler, don't have to cut front too much :) I like those old vs new pictures, so big job to get it that point.
What kind of wheel combo are You planning, maybe 9+10" as in swedish P7 :)
And rear axle bushing from where, I haven't seen Powerflex for P7, custom made?
Yea I just cut a small piece of each side, so the intercooler fits perfectly, radiator is mounted so there is space for 2,5" pipes.
Right now the wheels are gonna be 8x15" et10, but I'm looking for 8,5's and see if there's something i like.
The bushings are from an ep91, actually all bushings are, but for the rear axle I had to modify them a bit, so they fit well. Bought in UK.
  On 6/14/2016 at 11:39 AM, funny onion said:
I tired 8x15 et 10 on my P7 and they stuck out miles on the front! were ok on the rear though
I tested et35 8" front, those came out and no chance to turn wheels, rubbed everywhere :) Rear was ok with those, few mm cap inside :)
Okay, EP91 48,5mm rear bushing can fit to P7 axle, just ordered rear set last week, so front will fit also, thanks for info anyway.
It's also the front i'm a bit worried for, but it's 10 mm wider on each side, that's actually a lot when wheels need to be fitted. Think the rear needs spacers, so it looks the same front and rear. Or I could try et0 😄
Yes, can't remember the size I bought, there is 2 sizes on the powerflex website. But everything else fits like a glove, if you got a hydraulic press you get the best result.
  • 1 month later...
I finally got a little longer with my engine. I made a bunch of other stuff which isn't visible, like loom for gauges and power control. I also got the interior mounted, only missing a few bits and a speedo with rpm.
203D6573-3777-4396-9F58-AAD477756FF2_zps
E0B07BCC-FAF0-46A8-AC8A-19B3B1AFCDB9_zps
C021A4C0-B8A5-44AD-A5DD-2EBC2A614629_zps
BC02118C-21B9-4493-8F9C-A37A59A29FF2_zps
Intake is cleaned with a steel brush and then painted skyline sparkling silver as the rest of the engine bay. Trying to keep it simple and clean. All bolts and nuts are also cleaned before mounted.
CAC50A49-042F-4473-80E8-4B733EE8B64C_zps
95CA8785-76E3-4B51-95FC-83F2AD21AD71_zps
Just a pic of the interior. It's only the front seats that is gonna be mounted. I just need a strut in the rear and front.
9927128C-BAFE-4E31-8ADF-CE5E6A0FC578_zps
An aeromotive FPR is gonna keep the fuel pressure stable
79629186-C6AA-4CD4-AEEC-B9CFBEBB859F_zps
  • 1 month later...
A bit more happened today. Got some more stuff cleaned, painted and mounted on the engine, it's slowly getting there.
Matchporting of the intake manifold to fit the head perfectly and for optimal flow.
FEFE147D-7183-4E55-A246-2C4DCEEAC547_zps
Clean and as new. It's a huge job to clean and paint every single bit of the engine, but it looks nice when it's mounted
7AB50941-64B4-42FE-B481-AF8F64042928_zps
Fuelrail mounted with 560cc injectors, and ready for an6 adapter in the end, so it can be connected to my aeromotive fpr
EA5767FC-3100-475D-A6A3-EBA2756E6CE0_zps
Intercooler painted black for a stealth look, I don't like attention, so no shiny stuff
FB7512A1-A26A-45A5-B872-29F1879BC732_zps
Edited by PvflindtDK
  • 5 weeks later...
The engine starts to look lile something again.
7FF2D4BA-7637-4636-9E16-E8012D991CDE_zps
B1547EAA-E47E-4D58-A3BA-3BBCE1B39818_zps
I like my brand new WEPR td04 manifold. Gonne be mounted with my td05 turbo and an TiAL mv-s38 external wastegate
B16CE953-84DE-46DB-8B9A-E921D9B5EE21_zps
Gearbox is refurbished, although this isn't the box i'm gonna use for ever, I just gave it a quick clean and paint so it looks nice like the rest of the engine.
6F568C88-1179-4C6F-8419-E8E8C3F7A410_zps
And a wash of the car, in about 14 days the engine's getting in, new rims and upgraded brakes being mounted, can't wait!
AFD89D48-56E5-4D48-8894-C30EF4722C97_zps
