I have a standard bottom end and a race spec port and polished head what head gasket should I use athena or stock I want to push about 1.2 bar and 250bhp
Also should I use standard head bolts or arp
First most important thing is check piston and head inlet valve squishing area cap, there starts Your head gasket calculation, detonation will kill engine very easily and piston ring are first place were it starts. Max 1mm and under is way to go...
Go for an standard head gasket and head bolts mate if you go for a MLS Athena gasket your block will need decking
Edited by starletezy
Cheers guys will go for standard hg and bolts what kind of boost an db power does the stock hg and bolts hold if I was to go for more power in the future
So if I push 1.2 I would be playing with fire? What size thickness is the standard head gasket? What boost and hp will standard bolts hold
the stock h/gasket and stock h/bolts will handle the power and boost you mentioned above without issue----assuming you have oem/genuine items and your engine is in good condition
some people have pushed the stock h/gasket and h/bolts far beyond your goals...300++bhp, 1.5/1.7bar
you will need a good tune regardless
  • 1 month later...
