NICKYG2X3 Posted May 4, 2016 Posted May 4, 2016 car hoding back lambda sensor in post tomorrow? can i have a break down of what to check - thanks Quote
starletezy Posted May 4, 2016 Posted May 4, 2016 It could be a number of things mate It could be your ignition system or down to a vacuum leak or bad fuelling. What is the exact symptoms does it hesitate to start at all? does it cut off on its own? Quote
adzy Posted May 4, 2016 Posted May 4, 2016 Mine felt sluggish a while ago, especially around 70mph in 4th and 5th would make boost but just not accelerate much, also had a random misfire now and again.Changed spark plugs to copper ones and seems to have cured both Quote
NICKYG2X3 Posted May 4, 2016 Author Posted May 4, 2016 starts fine - drives pretty decent when giving it some revs - seems to make me change gear - notice it more in 3rd 4th tbh when wanting to let it rip in 5th also it should just fly but something holding it back il put sensor in today and buy some new spark plugs - thats prob what it is if no change will let you no Quote
gorganl2000 Posted May 5, 2016 Posted May 5, 2016 You done diagnostics check!? ^^^ do this and also check map sensor/connection, distributor, plugs, wires and 02 sensor/connection Quote
NICKYG2X3 Posted May 5, 2016 Author Posted May 5, 2016 (edited) vehicle speed error? - assume this was saved from the other day as speedo was not working - we fixed speedos so i imagine that was just a saved code - - no other codes? im miffed. and not that happy - dno what to do Edited May 5, 2016 by NICKYG2X3 Quote
haggis Posted June 1, 2016 Posted June 1, 2016 did you change sparks and 02 sensor ?mines kindof doing same but think im running really richsome guy had same problem tried everything and turned out his king leads were shot. he went from 129bhp to 170bhp no lie ( obviously had all the gear to go 170) but jist shows you how important ignition islet me know if you sort it man as i want to know Quote
NICKYG2X3 Posted June 4, 2016 Author Posted June 4, 2016 yes problem resolved. car was overboosting to fuckk. and was just not going any where in higher revs adjusted actuator your prob could be any of the above - distributor / spark plugs shot. etc Quote
