ashep91 Posted May 18, 2016 Share Posted May 18, 2016 will standard injections map to 1.2 bar or 1 bar if not what will they map to and if i need bigger injectors what size will i need for 1 bar and 1.2 bar Quote Link to post Share on other sites
Phil Posted May 18, 2016 Share Posted May 18, 2016 On what turbo and engine? assuming 4efte and ct9/td04 you should be ok with stock injectors. Phil Quote Link to post Share on other sites
ashep91 Posted May 18, 2016 Author Share Posted May 18, 2016 4efte and wepr hybrid stage 2 td044efete is stock Quote Link to post Share on other sites
Phil Posted May 18, 2016 Share Posted May 18, 2016 you'll probably be close to the limit at 1.2bar on that turbo. but your mapper will be able to tell you how close you are as he pushes the boost up. Phil Quote Link to post Share on other sites
RobSR Posted May 18, 2016 Share Posted May 18, 2016 mine were fine at 245 at 1bar on a larger turbo. Not in efficiency mind.. Quote Link to post Share on other sites
_shaun_ Posted May 18, 2016 Share Posted May 18, 2016 I ran stock ones on a td04 at 1.3 bar for about a year with no bother but they where maxed out basically Quote Link to post Share on other sites
ashep91 Posted May 19, 2016 Author Share Posted May 19, 2016 Cheers guys Quote Link to post Share on other sites
