Gents,
cant seem to find straight answer on this one...
fill to max cold ?
or
fill to 3/4 cold
or
fill to max hot
cheers
simon
sound colin,
only thing is it will expand and go past full when hot as it expands ?
like i put mine full when cold . then was doing some journeys checked when engine hot and its about 5 or 6 mm past the full line
When hot the oil might expand as much as maybe 200ml i wouldnt worry about over filling a smidge anyway.
On the 2000 plate corollas they had an oil burnig issue. The fix they gave was to put a different dip stick in so you added extra oil so it lasted between services 😂
I prefer to overfill the starlets a little, mainly because all mine burn oil and also id rather there was more oil in the sump when doing fast corners.
okay cheers i wont bother draining any this time then. i heard the oil seals can go if over filled so got a bit para
so full when cold is okay
