Oil Level Hot/Cold
sound colin,
only thing is it will expand and go past full when hot as it expands ?
like i put mine full when cold . then was doing some journeys checked when engine hot and its about 5 or 6 mm past the full line
When hot the oil might expand as much as maybe 200ml i wouldnt worry about over filling a smidge anyway.
On the 2000 plate corollas they had an oil burnig issue. The fix they gave was to put a different dip stick in so you added extra oil so it lasted between services 😂
