Murcuryrita Posted May 25, 2016 Posted May 25, 2016 I own a 1998 toyota starlet sportif and recently my E.M.L has been coming on and because my car is so old I could not get a full diagnostic test done, what they did do was tell me my air intake sensor and my coolant temp sensor were faulty which i have replaced, I also replaced spark plugs and battery hoping this would sort the problem but no.it seems to come on when car is cold and goes off when it gets hot can anyone help me with this issue. Quote
akyakapotter Posted May 25, 2016 Posted May 25, 2016 hey give this a try will tell you whats at fault hopefully http://www.toyotagtturbo.com/forums/showwiki.php?title=EFI+self-diagnosis+system cheers nick Quote
Murcuryrita Posted May 25, 2016 Author Posted May 25, 2016 (edited) Thanks for the reply but we already did that,that's how we found out about the sensors being faulty as for clearing the memory I'm not sure what to do. Edited May 25, 2016 by Murcuryrita Quote
akyakapotter Posted May 25, 2016 Posted May 25, 2016 i take out the efi fuse for 15mins will clear the codes Quote
Murcuryrita Posted May 25, 2016 Author Posted May 25, 2016 Where will i find that and how will i know its the right fuse. Quote
akyakapotter Posted May 25, 2016 Posted May 25, 2016 engine bay fuses and it tells you on the cover which one it is Quote
adzy Posted May 25, 2016 Posted May 25, 2016 i take out the efi fuse for 15mins will clear the codes About 15 seconds is all you need to remove it for to clear codes Quote
