Engine management light
I own a 1998 toyota starlet sportif and recently my E.M.L has been coming on and because my car is so old I could not get a full diagnostic test done, what they did do was tell me my air intake sensor and my coolant temp sensor were faulty which i have replaced, I also replaced spark plugs and battery hoping this would sort the problem but no.it seems to come on when car is cold and goes off when it gets hot can anyone help me with this issue.
  On 5/25/2016 at 10:08 AM, akyakapotter said:
i take out the efi fuse for 15mins will clear the codes :)
About 15 seconds is all you need to remove it for to clear codes
