dont waste your money man trust me I've been an auto electrician for years and these things alongside the whole earthing kits do absolutely fuck all
Yep not worth it. Best thing you can do is make sure you have good earths from the engine to the chassis/battery. The head to drivers side strut tower lead is quite small diameter so I tend to change that out for a larger diameter cable especially in setups where the battery is in the boot. Clean terminal to chassis/battery connections helps.
