Bean Posted April 27, 2020 Author Share Posted April 27, 2020 Not much of an update. trying to make myself get back onto this. Gave up finding someone to respray it. decided to just bash on with the turbo kit. One local guy came round to give me a price for respraying and it was 3-3.5k thats with no metal work as thats all done. Need to find someone more rreasonable. I got the oil return fitting welded into a spare B18 sump ive had for ages, i tried to tig weld it first but the torch is just that big on my welder and not a flexi one i just couldnt see what i was doing so i just mig welded it. I welded baffles into it years ago for my B18 eg civic i built and never ended up using it. Also gave it a quick sand down and primed, sprayed and clear coated it just to protect it more than anything. I had an old can of Toyota metalic black from my old 4wd starlet turbo so thought as its just a sump i would use it up as ive got that many aerosol cans in the garage ive had for years. Sump by Bean Beano, on Flickr Sump by Bean Beano, on Flickr Sump by Bean Beano, on Flickr Ive been trying to work out what im going to do wastegate wise for the turbo kit as the manifold is setup for twin gates which i just wont need, plus its more expense and alot more weight hanging off the manifold especially when you add on the screaner pipes. I wanted to just run the internal standard gate but im struggeling to find the male v band flange which would fit into the groove they have on them so they wont leak. Anyway yesterday i decided to just order another waste gate for the easiest solution. So i fitted one i already had and it hits the bonnet catch and also the rad and fan are in the way. So it turns out its not the easier solution at all! FFS! So ive now ordered some stainless 1.5" bends and a straight and im going to but the twin wastegate flanges off and have a go at running both of them into one wastegate in a better position out the way. Then ive just one screamer to make and i will probably add a brace somewhere just incase. I thought it was going to be pretty straight forward fitting this turbo kit. Also sourced a good condition evo 9 turbo which should be better than the evo 6 turbo i have currently. Just waiting on the guy finding a courier that will collect it. Quote Link to post Share on other sites
Bean Posted April 27, 2020 Author Share Posted April 27, 2020 (edited) ive been ordering a few bits n bobs for the teg that i needed for the turbo oil return and the water lines also the stainless bends to modify the wastegate setup. This is the start of the merge collector for the pipework going to the wastegate. Waste gate by Bean Beano, on Flickr Waste gate by Bean Beano, on Flickr This took me ages as i only have a dirty old chop saw and i had to get the angles bang on for a tight fitment. I then cut the old flanges off for a twin gate setup. This also took f00kin ages as i couldnt really get close enough with a grinder or the chop saw so i cut what i could with the grinder which wasnt much then switched over to a 3" air saw with a small blade which was super slow going and when that couldnt get in i had to use a tool like a dremel but with a bit more power with a tiny dremel disc in.Mani by Bean Beano, on Flickr So i clamped all the wastegate together when i welded everything to help prevent anything warping, which it didnt. Waste gate by Bean Beano, on Flickr Waste gate by Bean Beano, on Flickr Then i made this and got it all tacked up to check fitment.Mani by Bean Beano, on Flickr Mani by Bean Beano, on Flickr Really happy with the fitment i spent hours doing all this. Cutting the pipe trying pieces numerous times then prepping the pipe ect. and the last test fit! Test fit by Bean Beano, on Flickr The wastegate position is right where i wanted it, the screamer pipe will be a nice just straight piece of pipe so that will be easy to sort out. Edited April 27, 2020 by Bean Quote Link to post Share on other sites
Sam44 Posted April 27, 2020 Share Posted April 27, 2020 Really nice work. Quote Link to post Share on other sites
Bean Posted May 21, 2020 Author Share Posted May 21, 2020 On 4/27/2020 at 11:42 AM, Sam44 said: Really nice work. Expand Cheers Sam Not much of an update but i got the original sump off ready to fit the one ive baffled. 2 of the bolts were pretty rusty so i got thge rest out but gave them a spray with penetrating fluid and came back to them the following day. They both rounded off but one came out by banging a 9mm onto it. The last one snapped off 😢 Leaving this Dc2 by Bean Beano, on Flickr I got a big set of good quality mole grips on but it wouldnt budge. So i then tried welding a nut onto it but that wouldnt budge it so i tried welded nuts onto it another 2 times but still it wouldnt budge. So i just built it up with weld until it was glowing red, let it cool a bit then built it up some more and then cool then a bit more down the side of it. Dc2 by Bean Beano, on Flickr After this i got some grips on it and it was still tight but it started moving. Then i used a stud extractor and that wound it out easily. It was then stuck in my stud extractor so i usde the grips to get it off and thats why all the threads are damamged on it but its out now so happy days. Dc2 by Bean Beano, on Flickr I also decided to buy myself a big whiteboard to go on a wall in the garage to help me keep track of things as im always forgetting where im at with things and what i need to order or do next. So i got this fitted today and made a start on listing all the cars and what they need on it. It should come in handy. Dc2 by Bean Beano, on Flickr Ive got a boost solenoid coming and ive bought a dtm connector to use for the wiring for it. I bought the crimping too for the pins, ive not used these connectors before but they look really good without been silly money. Quote Link to post Share on other sites
Bean Posted May 21, 2020 Author Share Posted May 21, 2020 Sump fitted with the baffles and oil return, i wanted to get all new bolts back in this but tegiwa were out of stock and ive been checking the site and they just werent coming back in stock so i reused most of the old ones and used some decent ones from a b18c6 ive got in the garage. Always handy having spares laying about. Dc2 by Bean Beano, on Flickr New mishimoto mag sump plug arrived Dc2 by Bean Beano, on Flickr and fitted.Dc2 by Bean Beano, on Flickr Slow progress as usual but ive not been feeling too good the past week and a half so couldnt get anything done. Hopefully im on the mend now and can get the turbo bits on for the last time. Still searching for a cheap evo 9 turbo as the one i found the guy cant post it. I found one locally but its got a bit of shaft play so needs a rebuild really. I will keep searching. The Evo 6 turbo will do for now. Quote Link to post Share on other sites
Bean Posted May 21, 2020 Author Share Posted May 21, 2020 Boost solenoid landed. Dc2 by Bean Beano, on Flickr One of the differences between the B18c4 and the Type R B18 is this gearbox brace / flywheel cover. on the C4 there is just a small sheet metal flywheel cover and a bracket on each side of the engine. I removed this from a B18c6 ive got in the garage and gave it a quick clean up. Dc2 by Bean Beano, on Flickr and fitted. Dc2 by Bean Beano, on Flickr I then got the coolant lines made from AN6 braided hose and 45 degree black fittings from Torques. I have connected them up one from the idle control valve and the other from the fitting above the front radiator hose connector. This removes the coolant from passing through the throttlebody. Dc2 by Bean Beano, on Flickr Turbo end Dc2 by Bean Beano, on Flickr Oil return made up and fitted. Dc2 by Bean Beano, on Flickr I used a lamba sensor extension harness to conenct up my sensor.Dc2 by Bean Beano, on Flickr Making the hoses took longer than i thought it would, its been years since i made any of those. I havent tightened everything down fully yet as the shouldered nuts ive used on the turbo get a thread cut into them as you tighten them to help prevent them coming loose so i just want to make sure this is the last time the turbo ect is fitted! Feels like ive made some good progress today. Quote Link to post Share on other sites
Bean Posted May 21, 2020 Author Share Posted May 21, 2020 Thats the thread updated i had missed a couple of posts. Quote Link to post Share on other sites
Bean Posted May 22, 2020 Author Share Posted May 22, 2020 trying to get the intercooler into position so the bumper and stuff fits in place. 2020-05-22_03-38-46 by Bean Beano, on Flickr 20200522_205351 by Bean Beano, on Flickr peeking through the indicator hole. 20200522_191454 by Bean Beano, on Flickr i had to cut this bar out. More on this later. 20200522_191115 by Bean Beano, on Flickr 20200522_190201 by Bean Beano, on Flickr I also drilled the spot welds out on the piece which attaches to the bottom of the plate the bumper catch attaches to. This allowed me to get the intercooler right back. 20200522_190229 by Bean Beano, on Flickr 20200522_190209 by Bean Beano, on Flickr Thats about it for tonight. I plan to remake the square tube i cut out and incorporate a reinforcement brace for the bonnet catch piece i cut out which will also mount the intercooler to. Thats the plan anyway. No cutting of the bumper has taken place yet. Quote Link to post Share on other sites
Pikey009 Posted May 24, 2020 Share Posted May 24, 2020 Looking good mate. What did you use to seal the sump? Quote Link to post Share on other sites
Sam44 Posted May 24, 2020 Share Posted May 24, 2020 Great progress. I'm a big fan of these cars. There hard to beat. Quote Link to post Share on other sites
Bean Posted May 24, 2020 Author Share Posted May 24, 2020 (edited) On 5/24/2020 at 3:23 PM, Pikey009 said: Looking good mate. What did you use to seal the sump? Expand Cheers mate, i used a genuine Honda sump gasket, i also used a thin strip of scotchbrite the same width of the face on the block where the gasket sits to clean up the area so it was mint. I only put a tiny amount of RTV on each side where i think the oil pump joined the block and something else on the other side where i could see a thin line where it bolted up just incase. The Honda manual says you dont need to use any sealant to seal these sumps just the gasket and the correct tightening sequence and torque on the bolts/nuts. On 5/24/2020 at 7:52 PM, Sam44 said: Great progress. I'm a big fan of these cars. There hard to beat. Expand Cheers Sam they are such cool cars and drive awesome. As much as i love my starlets the tegs just drive and feel better on the road and it makes you want to put more effort into driving it the best you can. Hopefully i like the boost when its all done. If not ive got a rebuilt B18c6 Type R motor with skimmed head, spoon high comp headgasket, Skunk 2 high comp valves and retainers, so with a the right setup it could be quite a lively na setup. I went in the garage for a few hours tonight and got some pie cut and prepped. 20200524_213700 by Bean Beano, on Flickr Ive kept the pipework tucked in tight to the shell to keep the pipe run as short as possible, no issues with ground clearance, so they are not visable hanging under the car as i think it just looks crap when you see intercooler pipework hanging under the car, its lazy and just makes a poor job. I also dont want to cut the arch liners. 20200524_213733 by Bean Beano, on Flickr The pipe to the throttle body is slightly bigger thats why there is a gap where my new pieces join. I have a huge box full of new ali pipe so it made sense to use what i already had rather than buy even more material. 20200524_214359 by Bean Beano, on Flickr Also made the pics a bit smaller as i realised they were slightly too big. Tomorrows job i think i will either make a start on the hot side piping or maybe get this piece ive made tacked togther first, then when im happy with how everything fits have a big weldathon of both sides. Depending on how this setup goes on the welding side of things i have been watching some videos on making intercooler end tanks from ali sheet. I want to do a rear entry maybe just on the turbo outlet side as there is room for it and it will shorten the pipe run and just make a better job of it. I will likely buy another intercooler for this probably slightly smaller than this one and have a go. Edited May 24, 2020 by Bean Quote Link to post Share on other sites
Pikey009 Posted May 26, 2020 Share Posted May 26, 2020 Get that Celica sold to me to free up some cash for this Quote Link to post Share on other sites
Bean Posted May 26, 2020 Author Share Posted May 26, 2020 On 5/26/2020 at 8:30 AM, Pikey009 said: Get that Celica sold to me to free up some cash for this Expand Hahaha. 🤣 Quote Link to post Share on other sites
Bean Posted May 31, 2020 Author Share Posted May 31, 2020 I got a few more bits n pieces. a big delivery! 20200528_091921 by Bean Beano, on Flickr 20200528_092300 by Bean Beano, on Flickr and assembled 20200528_105220 by Bean Beano, on Flickr A swivel head bandsaw, which im absolutely loving! I got sick of the mess the chop saw was making of the pipework with huge burrs on it which took ages to tidy up and its just a rough old saw. it was also eating blades and makes such a mess, firing sparks everywhere. I got it setup and knocked out a load of pie cuts. This is the hotside piping from the turbo to the intecooler pretty much. As you can see its obvious which cuts were done on the chop saw and which were on the bandsaw. 20200530_174107 by Bean Beano, on Flickr 20200530_175824 by Bean Beano, on Flickr test fited. 20200530_173751 by Bean Beano, on Flickr and i made a start tacking it together. 20200530_202046 by Bean Beano, on Flickr I think im going to remake the parts i did with the chopsaw im just not happy with them. I got a few other bits but didnt get pics of them. The material arrived to make the new "crash bar" Quote Link to post Share on other sites
Bean Posted June 1, 2020 Author Share Posted June 1, 2020 i re did the old cuts in the bandsaw i couldnt leave them as i wasnt happy with the old chop saw cuts 20200530_175824 by Bean Beano, on Flickr 20200601_151025 by Bean Beano, on Flickr i just need to take my time welding it now. Quote Link to post Share on other sites
Pikey009 Posted June 1, 2020 Share Posted June 1, 2020 You’ll be starting up a shop soon! Quote Link to post Share on other sites
Bean Posted June 1, 2020 Author Share Posted June 1, 2020 On 6/1/2020 at 8:48 PM, Pikey009 said: You’ll be starting up a shop soon! Expand I work too slow mate i wouldnt make any money lol. Quote Link to post Share on other sites
Sam44 Posted June 2, 2020 Share Posted June 2, 2020 Are you mig weilding these Neat as always. I need to get a move on weilding my intake system together. I was going to get a pipe bender but I see there's another way. Quote Link to post Share on other sites
Bean Posted June 2, 2020 Author Share Posted June 2, 2020 (edited) On 6/2/2020 at 5:59 AM, Sam44 said: Are you mig weilding these Neat as always. I need to get a move on weilding my intake system together. I was going to get a pipe bender but I see there's another way. Expand Im trying to TIG weld them, this is the fist time ive had a go at making these before so its a bit of a learning curve. Some welds look decent other look poop. Have you got your eye on a certain pipe bender? I was getting this pipe welded up today and the head snapped off my tig torch. I only bought it 2 months ago 20200602_150122 by Bean Beano, on Flickr 20200602_150115 by Bean Beano, on Flickr Hopefully i can get my money back and buy the proper torch i should have bought last time. Edited June 2, 2020 by Bean Quote Link to post Share on other sites
Sam44 Posted June 3, 2020 Share Posted June 3, 2020 I thought I saw a mig torch head but yet I could see zero splatter on the weilds. I think this aprouch to making bends is alot better than using a pipe bender unless you use a mandrill or sand it's hard to bend tubing with out messing it right up. Keep up the good work. Ideas in action. I'm after a good tig weilder. If any 1 can recommend one. Quote Link to post Share on other sites
Calum122 Posted June 3, 2020 Share Posted June 3, 2020 Amazing work as always, I love your attention to detail. Very impressive. Quote Link to post Share on other sites
Bean Posted June 3, 2020 Author Share Posted June 3, 2020 (edited) On 6/3/2020 at 7:07 AM, Sam44 said: I thought I saw a mig torch head but yet I could see zero splatter on the weilds. I think this aprouch to making bends is alot better than using a pipe bender unless you use a mandrill or sand it's hard to bend tubing with out messing it right up. Keep up the good work. Ideas in action. I'm after a good tig weilder. If any 1 can recommend one. Expand You maybe did see a mig torch my garage is always a mess. Yeah you would have to spend alot to get a good bender and have to buy long lengths to fit it and probably wouldnt get the bends you need. this is the Tig welder ive got. i bought it about 7 years ago. Made in china but i got mine from italy as R-tech are the sole distributor of them in the UK https://www.ebay.fr/itm/352195085460?fbclid=IwAR2qbKmN1sPqQJyEJatMi71JUKoKaf6MWrhPDbcQii-_qHztEBYM6egBIJ0 You can buy it from R-tech here r-tech As you can see there is a big difference in price. R-tech are a great company though and their service is really good. I took a bit of a gamble on mine and its had no issues. Its a 200 amp AC/DC machine with pulse so it has everything you coud ever need and will do both aluminium and steels. Edited June 3, 2020 by Bean Quote Link to post Share on other sites
Bean Posted June 3, 2020 Author Share Posted June 3, 2020 (edited) I had a review of all the dc2 jobs on my whiteboard and i actually wiped a couple off which i had done so that was good. I then saw one that said about making the screamer pipe so that spured me on to get that done. Cutting the pieces. 2020-06-03_09-51-15 by Bean Beano, on Flickr The bandsaw isnt half earning its keep. I got some pies cut for the bend. 20200603_220715 by Bean Beano, on Flickr I think i got a bit carried away as when i started trying pieces up it looks like i only need two of them haha. 20200603_220703 by Bean Beano, on Flickr Im gonig to put my old tig torch back on the machine tomorrow and get the screamer tacked up. I will wait for my new torch to come to weld it though. I also made a start on the new crash bar / intercooler mounting bar which is now tacked onto the car. I went to cut the next section to run across the intercooler though and when i cut the box section and flipped it over i noticed the box isnt welded or it has failed as i could see gaps in it and in other parts of it too. 20200603_220703 by Bean Beano, on Flickr 20200603_170123 by Bean Beano, on Flickr 20200603_170140 by Bean Beano, on Flickr So thats no good. im waiting to hear back from the steel seller, hopefully he will send me a non defective piece out. Also had a few issues with my band saw and the company have said it will have to go back to be replaced 😣 the vice mounting points are 15mm out of spec which is causing the saw to come in contact with the wheel used to adjust the vice which shouldnt be happening. Theres also a couple other minor issues but thats the reason it needs to go back. Everything seems to be going wrong first the tig torch, then the box section now the band saw! Edited June 3, 2020 by Bean Quote Link to post Share on other sites
Pikey009 Posted June 4, 2020 Share Posted June 4, 2020 Annoying set backs mate but the positive to take is that non of it is your fault. So when you’ve got the right bits you’ll smash it Quote Link to post Share on other sites
Bean Posted June 4, 2020 Author Share Posted June 4, 2020 (edited) On 6/4/2020 at 7:42 PM, Pikey009 said: Annoying set backs mate but the positive to take is that non of it is your fault. So when you’ve got the right bits you’ll smash it Expand Yeah cant be helped mate just annoying. I order ALOT of stuff and i guess thats the down side of not picking stuff up locally. I think i am just taking advantage of always been in for the couriers while im off work for so long. This mornings job was sorting out quality issues! New piece of steel getting sent out today and new band saw getting sent out today. New tig torch sent out. Hopefully that will be everything sorted for now. Back to the car. Even though the box section will be no good to use i thought i might aswel make a piece up then i can copy its dimensions and angles when the replacement stuff comes. I cut the angles on the bar to run just above the intercooler. its just wedged in there so not quite straight. 20200604_204020 by Bean Beano, on Flickr then i thought i would have a go at making the mounts which i will weld onto the intercooler. so i cut some of the aluminium round bar which arrived today drilled and tapped it just to see if it was going to work out.20200604_204045 by Bean Beano, on Flickr and placed under the bar to show how im going to mount the core. I will probably do three of these along the top and drill through the box section to then bolt through it. I also straightened the odd few bent fins on the core and cleaned up any bits of rust on the crash bar mounts on each side. 20200604_204128 by Bean Beano, on Flickr This must be the worlds longest intercooler install 🤣 Edited June 4, 2020 by Bean Quote Link to post Share on other sites
