5e colin Posted July 29, 2016 Posted July 29, 2016 hey lads got my car of the computer and we cant do castor as its not programmed in the computer ( under starlet ) what car do ye use on the comp to get your casttor set ?? as i can feel its not the same on both sides Quote
richardc9052 Posted July 29, 2016 Posted July 29, 2016 Settings might not be there but if it. An do castor surely the live readings are there? Just try and match the two. Then readjust toe Quote
daniel_g Posted July 29, 2016 Posted July 29, 2016 Depends on the machine but cant you just select generic alignment, not starlet specific.Select toe, castor, camber for front.True straight for rear if you want to set up panhard.Adjust as required. Quote
5e colin Posted July 29, 2016 Author Posted July 29, 2016 `no cant as im not allowed to touch the machine they dont have a universal setting they hang reflectors on your 4 wheels and 2 robot poles with sensors going up and down and spray beams at the plates Quote
5e colin Posted August 21, 2016 Author Posted August 21, 2016 bump so al the 100s op cars running the anti lift kits have not done there castors ???? Quote
richardc9052 Posted August 21, 2016 Posted August 21, 2016 I dont think anyone sets them to a specific degree. They just make both sides even. its not like we have that much adjustability.. max 1 deg over standard. Unless you have castor adjustable top mounts.. Quote
5e colin Posted August 21, 2016 Author Posted August 21, 2016 you see if your 2mm of onj the bush your like going to get alignment isseus like always pulling etc etc ( wich i have atm ) she is dead strait tracked but still pulls a bit di9d not before the alk Quote
richardc9052 Posted August 21, 2016 Posted August 21, 2016 Your going to have to figure it out yourself.. But like you said, you cant touch the machine when tracking so what would the numbers help with anyway?Just align the wheels so they are level. The way the alk adjusts castor is by pushing the ball joint forward, pivoting the whole wishbone around the front mounting by pushing the rear mounting to the outside of the car. So you could measure the angle from the front mounting to the balljoint on both sides, then adjust until they match. Quote
