epcashin Posted August 22, 2016 Posted August 22, 2016 just a quick question on the adjustable panhard goin to lower my starlet more and fit one of these and want to get it properly 4 wheel aligned and tracked but will they mechanics tracking it be able to adjust the rod ?and whats the best camber setup on the front to have before i get it tracked and alinged ?any info will be helpfulalready have rear arb uprated front one etcjust literaly to finish it off proper have meister r coils 2 Quote
Starlet__SR Posted August 22, 2016 Posted August 22, 2016 It depends which bar it is, some can be adjusted on the car, others have to be removed. Quote
epcashin Posted August 22, 2016 Author Posted August 22, 2016 i have a whiteline adjustable one just want to know the proper way to set it up Quote
richardc9052 Posted August 22, 2016 Posted August 22, 2016 (edited) Best bet is to measure the length of the standard one and set it to that height. You can then adjust until its centred by unbolting one end, adjusting and then refitting a few times. Or if you are any good at math, its basic trig. Edited August 22, 2016 by richardc9052 Quote
epcashin Posted August 22, 2016 Author Posted August 22, 2016 Yes but I mean I will have the car low enough so Wat way does the pan hard rod have to be to be perfect ? Quote
Starlet__SR Posted August 22, 2016 Posted August 22, 2016 Easiest way is to stick a plumb line over each rear arch. Measure the distance between rim and the plumb. Adjust to suit. Tighten then give the car a run. Recheck then do wheel alignment Quote
H_D Posted August 22, 2016 Posted August 22, 2016 use an alignment/tracking company who use hunter equipment - they have the proper geomentry settings for imports Quote
richardc9052 Posted August 22, 2016 Posted August 22, 2016 Yes but I mean I will have the car low enough so Wat way does the pan hard rod have to be to be perfect ? Theres no set length.. You have to figure it out through measurement with a little trial and error. Quote
Ollieh17 Posted August 23, 2016 Posted August 23, 2016 I've always done it by eye and never had an issue. Quote
