  On 8/30/2016 at 10:13 AM, Ollieh17 said:
Not necessarily true, a 3an line would provide restriction anyway
Just speaking from my previous experience with the vf and TD. The an3 line will provide a slight restriction I agree 👍🏻
Do subaru even use one from standard? did loads of research on this when fitting a brand nee turbo. Its each to there own i suppose. Why not try it without a restrictor,if its smoking then fit one.
An3 again is garrett JOURNAL BEARING advice....
Well its not as journal bearings run very similar to crank and rod bearings. Guess garrett in all there wisdom must be completely wrong
The journal bearing system in a turbo functions very similarly to the rod or crank bearings in an engine. These bearings require enough oil pressure to keep the components separated by a hydrodynamic film. If the oil pressure is too low, the metal components will come in contact causing premature wear and ultimately failure. If the oil pressure is too high, leakage may occur from the turbocharger seals. With that as background, an oil restrictor is generally not needed for a journal-bearing turbocharger except for those applications with oil-pressure-induced seal leakage. Remember to address all other potential causes of leakage first (e.g., inadequate/improper oil drain out of the turbocharger, excessive crankcase pressure, turbocharger past its useful service life, etc.) and use a restrictor as a last resort
Reason td04 may need one is because they are battered and probably nearing the end of their life. Restrictor may just prolong the issue. Ive killed two td04s and think it was down to the restrictor. Line was fine no blockages and both had munched bearings. Primed before hand etc.
I can't be fucked to argue anymore, the information is there from experts. Go with whatever...not my car lol
  On 8/31/2016 at 9:33 AM, Starlet__SR said:
By fitting a restrictor you're impeding flow not pressure. All you'll be doing is creating pressure before the turbo. If you want to lower pressure than you need to run a larger diameter feed line.
yes you are altering pressure the turbo oil feed is before the oem oil pressure relieve valve !!!!
