Matthewep91v Posted September 2, 2016 Share Posted September 2, 2016 I have just bought some toyota injector seals from ID-Workz and I am having trouble getting them to seal properly they are just pissing out fuel. Am I doing somthing obviously wrong is there a special way of fitting them.Standard fuel rail with tuning developments 430cc yellow injectors Quote Link to post Share on other sites
parker85 Posted September 2, 2016 Share Posted September 2, 2016 use some vaseline on them mate i had same problem tryna seal them there a nitemare Quote Link to post Share on other sites
Starlet__SR Posted September 2, 2016 Share Posted September 2, 2016 Vaseline, silicone grease. Pack plenty in Quote Link to post Share on other sites
5e colin Posted September 2, 2016 Share Posted September 2, 2016 if you did it dry there might be cuts already in the o rings new 1s will be needed then Quote Link to post Share on other sites
Matthewep91v Posted September 2, 2016 Author Share Posted September 2, 2016 All sorted used a bit of lube and they sealed up Cheers for the replys Quote Link to post Share on other sites
daniel_g Posted September 2, 2016 Share Posted September 2, 2016 Bit of spit normally does the trick Quote Link to post Share on other sites
