Matthewep91v Posted September 2, 2016 Posted September 2, 2016 I have just bought some toyota injector seals from ID-Workz and I am having trouble getting them to seal properly they are just pissing out fuel. Am I doing somthing obviously wrong is there a special way of fitting them.Standard fuel rail with tuning developments 430cc yellow injectors Quote
parker85 Posted September 2, 2016 Posted September 2, 2016 use some vaseline on them mate i had same problem tryna seal them there a nitemare Quote
Starlet__SR Posted September 2, 2016 Posted September 2, 2016 Vaseline, silicone grease. Pack plenty in Quote
5e colin Posted September 2, 2016 Posted September 2, 2016 if you did it dry there might be cuts already in the o rings new 1s will be needed then Quote
Matthewep91v Posted September 2, 2016 Author Posted September 2, 2016 All sorted used a bit of lube and they sealed up Cheers for the replys Quote
