J40k-mo Posted September 25, 2016 Share Posted September 25, 2016 Has anyone got a tutorial of stripping the gearboxes down? Is it as simple as it looks with taking the bolts out and stripping the casings off? Or is there a special way and clips under certain bolts that need to be removed etc? Thanks Quote Link to post Share on other sites
5e colin Posted September 25, 2016 Share Posted September 25, 2016 hemm its not simple attal dont do your first if you havent a spare unless really competent make sure to lay out everuthin in order so it goes back right way ] just work your way down getting 5th gears of might be tricky ( brake ) after that the casing can come of Quote Link to post Share on other sites
J40k-mo Posted September 25, 2016 Author Share Posted September 25, 2016 Is 5th gear on its own in the end cap? Like 5th has to be taken out before the casing comes off? Also one box I just want to get the diff out and the other 5th haha, is the diff a straight forward job with the front casing off? Quote Link to post Share on other sites
5e colin Posted September 25, 2016 Share Posted September 25, 2016 kinda ya but getting the diff out without 5th coming off means fucking around with 2 hidden bolts inside there a real cunt to fit back if you have the tools then strip it completely Quote Link to post Share on other sites
J40k-mo Posted September 25, 2016 Author Share Posted September 25, 2016 Thanks mate Quote Link to post Share on other sites
5e colin Posted September 26, 2016 Share Posted September 26, 2016 i9f you get stuck take some pics and upload here Quote Link to post Share on other sites
Mike-530 Posted September 26, 2016 Share Posted September 26, 2016 If you are anyway near leicester, i know a gearbox mechanic if you need? Charged 250 for a strip down and health check with new genuine input shaft bearings. Cheers Quote Link to post Share on other sites
Phil Posted September 26, 2016 Share Posted September 26, 2016 Is 5th gear on its own in the end cap? Like 5th has to be taken out before the casing comes off? Also one box I just want to get the diff out and the other 5th haha, is the diff a straight forward job with the front casing off? kinda ya but getting the diff out without 5th coming off means fucking around with 2 hidden bolts inside there a real cunt to fit back if you have the tools then strip it completely I would def go for diff only personally. IF thats all your looking to achieve. The two bolts inside are shown on tuturials on TGTT or here maybe, and the are easy fitted back together if you fit the reverse selector very loosely using one bolt before reassembly Phil Quote Link to post Share on other sites
aleximport25 Posted September 26, 2016 Share Posted September 26, 2016 When I replaced a broken centre housing on my box I found taking photos of every stage helps and like colin said lay everything out in the order it came off in Quote Link to post Share on other sites
richardc9052 Posted September 26, 2016 Share Posted September 26, 2016 You don't need to touch the two bolts for the reverse selector of you remove the ball bearing it just slides out when you lift the bellhousing off, then slide it back in before closing box back up Quote Link to post Share on other sites
Phil Posted September 26, 2016 Share Posted September 26, 2016 You don't need to touch the two bolts for the reverse selector of you remove the ball bearing it just slides out when you lift the bellhousing off, then slide it back in before closing box back upI am pleased to learn thisPhil Quote Link to post Share on other sites
5e colin Posted September 27, 2016 Share Posted September 27, 2016 me to will be testing that soon richard took me more then 2 hours getting them 2 bolts back in with my chunky fingers i could barely get them in the gap let alone with a bolt in my fingers Quote Link to post Share on other sites
gorganl2000 Posted September 27, 2016 Share Posted September 27, 2016 just on a side note...it may be best to double check the availability of the specific parts you need for you gearbox nowadays, as some things are discontinued Quote Link to post Share on other sites
J40k-mo Posted September 27, 2016 Author Share Posted September 27, 2016 Hello lads, I took end cap off and selector fork and everything is smashed to bits, I couldn't get the gears of the shaft though? Are they pressex on? And I have another box with a kaaz lsd in that I want to take out, I want to see what order the Plate are in. Has anyone got a link to the tutorial on removing the diff? And stripping the boxesI removed the Sir clip on 5th gear and the nut on the other gear but both wouldnt move, does that plate have to come off that's behind it? And take it all off together? Quote Link to post Share on other sites
5e colin Posted September 28, 2016 Share Posted September 28, 2016 you need good gear pullers to take 5th gear cog off the diff ( only ) tutorial is on toyotagtturbo.com >>>>>>>>>http://www.toyotagtturbo.com/forums/showthread.php?83777-A-guide-to-fit-an-aftermarket-Quaife-LSD Quote Link to post Share on other sites
Phil Posted September 28, 2016 Share Posted September 28, 2016 You don't need to open the rear casing to remove the diff onlyIf things are smashed it's probably worth swapping the LSD into a good box and fit itPhil Quote Link to post Share on other sites
J40k-mo Posted September 28, 2016 Author Share Posted September 28, 2016 Thanks lads Al get diff out tonight Quote Link to post Share on other sites
TimD Posted September 28, 2016 Share Posted September 28, 2016 the diff ( only ) tutorial is on toyotagtturbo.com >>>>>>>>> http://www.toyotagtturbo.com/forums/showthread.php?83777-A-guide-to-fit-an-aftermarket-Quaife-LSD Where can I find the magical ball bearing which means I don't have to faff about with the 2 hidden bolts? I need to do the same as you, inspect my Kaaz diff! Quote Link to post Share on other sites
J40k-mo Posted September 28, 2016 Author Share Posted September 28, 2016 Have you got a Photo of the order of the plates?? The one I have got on this post won't load up Quote Link to post Share on other sites
TimD Posted September 28, 2016 Share Posted September 28, 2016 I've dropped coordsport an email to see if they know why it has broken.. http://www.ponycars.net/images/rx7/KAZZ.bmp I'm pretty certain that's the same thing Quote Link to post Share on other sites
J40k-mo Posted September 28, 2016 Author Share Posted September 28, 2016 Yes mate that's the one, I've done mine, struggles with them 2 12mm bolts but managed it haha, and the diff was. Set on super hard so no wonder it was like it was, set it to soft for now to see how it goes Quote Link to post Share on other sites
