jatelo Posted September 26, 2016 Posted September 26, 2016 (edited) Title says it all... Had a minor service coming up for my EP91 and did the usual - oil & oil filter change, spark plugs change, air filter change and a check on the state of my brakes. Problem started after the throttle was cleaned with carb cleaner, from the outside (it wasn't dismantled at all). The car now has an irregular idle that disappears when the car is running at highway speed, and rears its head when i'm in traffic or on low gears (1&2) and driving at a slow speed. Moreover, there's no check engine on the dash. I've tried several solutions: disconnecting the battery for 10-15 minutes, cleaning the whole throttle body, swapping the throttle body with another from a working fine starlet and putting back the old plugs. The problem still persists. I've checked the distributor + lead wires but they're all firing in good order. Did a diagnostics on the car as well but no significant error showed up. Lads, i'm at a loss on what the problem might be. Any advise and suggestion on this issue is welcome. Let's put our thinking caps on Cheers! Edited September 26, 2016 by jatelo Quote
jatelo Posted September 26, 2016 Author Posted September 26, 2016 I've also checked the sensors and the lines for vacuum leaks but it's an all clear from that end. I'm honestly stumped on what the issue might be. Quote
jatelo Posted September 27, 2016 Author Posted September 27, 2016 So much for fountain of knowledge Quote
Nafeez2125 Posted September 27, 2016 Posted September 27, 2016 what i can suggest is to check your thermostat sometimes when its stuck open it will mess up everything because the coolant temperature will not reach optimum working temperature therefore the ecu will think your engine is cold and will over fuel it and idle control valve will be wide open thinking that the engine needs more air. thats why its idling high second option is the coolant temperature sensor itself is faulty and third option is the throttle position sensor Quote
patman Posted September 27, 2016 Posted September 27, 2016 I would also definitely check for blocked lines coming from the throttle body 👍🏻 Quote
jatelo Posted September 28, 2016 Author Posted September 28, 2016 Problem sorted! Found a leak in the throttle body. Hard to explain because I had a professional sort it out from his workshop as I was slogging away at work.Cheers Patman and Nafeez! Quote
Nafeez2125 Posted September 28, 2016 Posted September 28, 2016 (edited) When you said leak you mean la leak in throttle body the gasket or somewhere inside? Glad that your problem is sorted mate. Edited September 28, 2016 by Nafeez2125 Quote
patman Posted September 28, 2016 Posted September 28, 2016 I'm glad I was on the right lines glad you sorted it mate 👍🏻 Quote
jatelo Posted September 30, 2016 Author Posted September 30, 2016 Cheers Patman! Nafeez mate, the mechanic specified the leak coming about from a faulty throttle component that allowed air inside when the throttle was closed. He wasn't very clear with the explanation so planning on seeing him sometime this weekend as soon as I get time off work so he can point out what he did. Tbh, i'm befuddled by his explanation hence the need to swing by his workshop and get some clarifications. I'll update the thread when I get the info. Quote
Calum122 Posted October 1, 2016 Posted October 1, 2016 I would have said sounds like an air leak. Which would explain why it didn't show itself at high speeds. Quote
