Hi guys. once again, the minute I get my car fixed another problem decides to jump out.
I took my alternator off to change the belt and sort out a small oil leak from the dipstick tube. I replaced it all fine started the car up and it was working all fine so I turned it off and went to lock it and my fob didn't lock it so I manually locked it.
A few hours later I got my delivery for a turbo to manifold gasket. so I decided to take my turbo setup off to change the gasket. I changed that all fine. once I changed that I went to start my car and it wasn't cranking over. when I put my keys in the barrel it was beeping at me like it normally does and the light to say a door was open came on. so I then turn the ignition on and obsoletely nothing. I get no lights on the dash what so ever its like the car is still immobilized or something. when i press the buttons on my fob a little blue light signals that I'm pressing it so the batterys not dead on my fob and i tried connecting a jump pack to my battery and still exactly the same thing was happening. I'm soo confused why this is happening.#
any help would be much appreciated
really starting to get fed up with this now.
Im with trisk on this! sounds like your alarm/immobiliser is pissed at you.
did you unplug your battery to do all the work? sometimes that can cause probs with the immobiliser if you didn't activate it before unplugging battery.
James
