SpikeyJp_68 Posted November 23, 2016 Posted November 23, 2016 Rubber seals... not swimming ones. Anyway, I bought a full gasket set online and there's a few seals I'm not sure about if anyone could identify them for me ? I know these already4: rocker cover grommets5: valve stem oil seals 6: spark plug tube sealsAfter that I'm not sure. Here's a side pic of no. 8Many thanks in advance Quote
Gary91 Posted November 23, 2016 Posted November 23, 2016 1 - Gasket for bottom of cat7 - injector o-rings8 - injector seals9 - camshaft seal Can't think what 2 and 3 are for Quote
5e colin Posted November 23, 2016 Posted November 23, 2016 1exhaust2 dizzy o ring in camshaft cap3?7 and8 Injectors seals 9 exhaust cam oil seal behind cog Nr 3 I'm blank on Quote
SpikeyJp_68 Posted November 23, 2016 Author Posted November 23, 2016 Cheers lads ! Here's a close up pic of no.3 Quote
SpikeyJp_68 Posted November 23, 2016 Author Posted November 23, 2016 Injecter o rings ?I thought they could be the ones at the top ? I dismissed that though as there's 5 of them Quote
morgey Posted November 23, 2016 Posted November 23, 2016 One for the dipstick or one for the FPR? Quote
SpikeyJp_68 Posted November 23, 2016 Author Posted November 23, 2016 One for the dipstick or one for the FPR?Dipstick is a good shout never thought of that. If it fits, it sits Quote
SpikeyJp_68 Posted November 23, 2016 Author Posted November 23, 2016 Also, valve stem oil seals; anyone know which is intake which is exhaust ? They seem to be slightly different Quote
fiddlersport Posted November 24, 2016 Posted November 24, 2016 Did you buy this kit for 4efe or 4efteUsually the darker seals are for exhaustWhat brand is the kit also ? Quote
SpikeyJp_68 Posted November 24, 2016 Author Posted November 24, 2016 Did you buy this kit for 4efe or 4efteUsually the darker seals are for exhaustWhat brand is the kit also ?For 4efte. This is it here >http://japserviceparts.co.uk/products/toyota-parts/toyota-starlet-gt-turbo-ep82-head-gasket-set-made-in-japan-4e-fte.html?___SID=UWill find out the brand tonight Quote
StuDoc 72 Posted November 24, 2016 Posted November 24, 2016 Is that not the Victor Reinz set just repackaged? Quote
SpikeyJp_68 Posted November 24, 2016 Author Posted November 24, 2016 (edited) Is that not the Victor Reinz set just repackaged?I don't think so, it has a brand name on the backing cardboardBut it might be I'm not sure Edited November 24, 2016 by SpikeyJp_68 Quote
StuDoc 72 Posted November 24, 2016 Posted November 24, 2016 http://www.ebay.co.uk/itm/FOR-Starlet-1-3-EP91-EP82-GT-Turbo-Glanza-Engine-Head-Gasket-Set-Seal-Bolt-4EFTE-/151388924925 Not that then? Quote
SpikeyJp_68 Posted November 24, 2016 Author Posted November 24, 2016 (edited) No didn't come in that packaginghttp://www.ebay.co.uk/itm/FOR-Starlet-1-3-EP91-EP82-GT-Turbo-Glanza-Engine-Head-Gasket-Set-Seal-Bolt-4EFTE-/151388924925 Not that then? Edited November 24, 2016 by SpikeyJp_68 Quote
