StanMan Posted November 30, 2016 Posted November 30, 2016 (edited) I have been doing a bit of searching as to putting in an oil temp gauge. However all the posts I find are old and the images/links don't work. As far as I can tell, the best way to do it is to get a 1/8th BSPT t-piece and relocate the oil pressure sender? Would THIS do the trick? Bit concerned as to the length of the line messing with the pressure reading. Or would something like THIS be more suited? Thinking about it will a temp sender even fit? Sorry if this has been asked and answered loads of times before and I cant find the post. Edited November 30, 2016 by StanMan Quote
Stu Posted December 1, 2016 Posted December 1, 2016 It may pay to narrow down what oil temp sensor you are going to use first, some of them are quite long and wont work in those links you showed. I have used these http://www.nzefi.com/product/bosch-engine-oil-temperature-sensor/ and these http://www.nzefi.com/product/oil-temperature-sensor-with-right-angle-connector/ Quote
akyakapotter Posted December 1, 2016 Posted December 1, 2016 Mine is in the blank on the oil filter housing. with a hole drilled into the power steering bracket. Have a look in my build thread its there some where Cheers nick Quote
T-dog Posted December 1, 2016 Posted December 1, 2016 I've done the same works a treat ^^^^ https://www.ebay.co.uk/itm/272391273919 https://www.ebay.co.uk/itm/261974520834 Used these 2 items Quote
akyakapotter Posted December 1, 2016 Posted December 1, 2016 P.s done the same for water temp off the thermostat housing same adapter Cheers nick. Quote
StanMan Posted December 1, 2016 Author Posted December 1, 2016 On 12/1/2016 at 6:12 AM, akyakapotter said: Mine is in the blank on the oil filter housing. with a hole drilled into the power steering bracket. Have a look in my build thread its there some where Cheers nickSeems like the best idea. Just having a look now, nice build thread Thanks for the suggestions guys. Quote
