Oil Temp Sensor
I have been doing a bit of searching as to putting in an oil temp gauge. However all the posts I find are old and the images/links don't work.
As far as I can tell, the best way to do it is to get a 1/8th BSPT t-piece and relocate the oil pressure sender? Would THIS do the trick? Bit concerned as to the length of the line messing with the pressure reading. Or would something like THIS be more suited? Thinking about it will a temp sender even fit?
Sorry if this has been asked and answered loads of times before and I cant find the post.
Edited by StanMan
Mine is in the blank on the oil filter housing. with a hole drilled into the power steering bracket. Have a look in my build thread its there some where :)
Cheers nick
Seems like the best idea. Just having a look now, nice build thread :) Thanks for the suggestions guys.
