matthewthomas Posted December 5, 2016 Posted December 5, 2016 Does any one know what could be causing this to happen? Quote
Gainzy Posted December 5, 2016 Posted December 5, 2016 Running higher boost without a higher boost cap rating Quote
matthewthomas Posted December 5, 2016 Author Posted December 5, 2016 Only running .65 of a bar so near to standard I'm gonna try a new rad cap see if that works Quote
epcashin Posted December 5, 2016 Posted December 5, 2016 if its blowing it into expansion bottle ? head gasket is goneports be blocked Quote
matthewthomas Posted December 5, 2016 Author Posted December 5, 2016 Don't feel like I'm down on any power tho Quote
matthewthomas Posted December 5, 2016 Author Posted December 5, 2016 Plus she's not overheating Quote
Fizturbo Posted December 5, 2016 Posted December 5, 2016 Does any one know what could be causing this to happen? Quote
morgey Posted December 15, 2016 Posted December 15, 2016 Get a garage to sniff test the coolant to check for head gasket. If clear try a different rad cap Quote
Nafeez2125 Posted December 30, 2016 Posted December 30, 2016 i had this problem before and it was the radiator cap. replaced it with a 1.1 bar cap problem solved. Quote
