Strange tapping noise coming from my V
Hi guys been got this strange tapping noise on my glanza just wanna see if anyone can shine some light on this or have experienced the same noise and before anyone asks
The timing is okay
There is enough oil in there
Dropped the sump and shells are all good
Took the rocker cover off and nothing seems loose under there
Video https://youtu.be/9RqE14seygc
Also the alternator bearing is very squeaky lol
Never have this problem, suddenly tapping noise started and I was sure that my oilpump blewed, sound came belt area. Found that my lower plastic cover somehow was touching cranck alternator wheel or oilpump wheel. Pushed cover 1mm inside and sound was gone. After that some hot air blower and bended it inside little bit...
Knock knock, maybe it is santaclaus came to your door too early, baddest choise :/ Or one valve fail is possible, locking nails popped out or snapped valve...
Just my luck lol will check for what you've posted mate thanks for the comment 😃
sounds like blown out gasket between turbo and mani
Yeah I don't know which one it is lol I'll replace the lot
