Advice please, 96 GLANZA V
In mostly cold starts it misfires for about 5 seconds before running on all cylinders and never misfires again. Also when I've just parked up after driving and go to start it again it takes a little longer than usual to fire up.
I was thinking coolant temp sensor maybe?
All the ignition system is brand new, plugs, dizzy, rotor arm, leads.
Any help would be appreciated
After the coil i would suggest checking your battery and alternator, because if your battery doesn't have enough juice it can cause the misfire on start up and long cranking. Start up uses a lot of current.
Replaced coolant temp sensor, turns out it was basically snapped. Made it alot better but still missing... Going to try coil next, are they easy to remove?
